Autora/Riv mirrors
Autora/Riv mirrors
Aurora/ Riviera mirrors on a c3, has anyone still on this forum done this and how difficult was it?
Corvette vs. F-Body Sport Mirror
If you have the factory Sport Mirrors, you may already be aware of this and I apologize beforehand if you are. Many folks unknowingly purchased and installed Camaro/Firebird sport mirrors on their Corvettes back in the day. They were more readily available and often less expensive. Unfortunately most folks didn't realize that there was a difference in the two mirrors, they appear identical unless you see them side-by-side or measure them. The Corvette mirror has a pedestal that is about an inch taller than the F-body mirror pedestal. This inch makes a substantial difference in the rear view.
This is what the pedestal on the Corvette looks like...
It doesn't provide a perfect view, but it is much better than the view through the F-body mirror.
Good luck... GUSTO
Good luck... GUSTO
You have to drill new holes. just use gasket to mark holes and drill, u can use one existing hole and go from there. Pretty straight forward if you're not adding all the electrics maybe some shaving but not sure if its needed. They look cool in pictures but I personally like the c6 ones better but aurora and rivs can be found at any pick your part.
