I recently read somewhere(don't remember where,getting old sucks) that G.M. is selling a forged 427 crank for about $300,can anybody point me in the right direction.I did a search on the forum and nothing came up. thanks in advance for any help.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Been curious myself about the availability of a factory 427 crank. The only part number I see listed in the GM Performance parts catalog is 10114186, but that's for a Gen V and Gen VI engine. I'm building a new engine this summer, and am trying to decide whether to sell my short block and buy new stuff, or just transplant the internals of my present (track) engine. Finding a reasonably priced crank with a decent pedigree would certainly help in the decision making process.
I'm going to build a 427 this summer using a 454 block. You can use a 366 truck crank and rods to destroke the 454. The truck cranks were steel cranks also.
Ck Competion Products....they used to have a bunch of leftover GM "blems" for sale cheap. I know a fellow running one of them in a 4.600x3.76 840HP@8100 rpm Vette. He shifts at 8600 and has been doing it for years. No issues. Runs low-mid 9's on motor.
The 366's are another way to do it if you balance everything correctly. Or even 427 truck cranks are basically the same thing.
JIM
I bought two of the 427 cranks from competition products they were
$99.00 apiece and the shipping was free, next door nieghbor has
them now.
FYI....366 truck cranks for GEN V/VI blocks are all cast, and not all 427 GEN V/VI cranks are fordged, so be careful if you think your buying fordged and you pay for fordged only to find out that its really cast.
greg
I did a similar thing, as my current track motor is a swap meet 427 crank in a later vintage 454 block (the original engine is enjoying a comfortable retirement under my work bench). Regarding the 366 crank (of which I admit I know nothing about), is there any issues about having to add a great deal of material to the crank to restore balance with the bigger 427 pistons? My Chevy BB Interchange book mentions some differences between 396/402 and 427 cranks, that being mainly the size of the #3 counterweight. Just curious if the 366 crank has narrower counterweights given that the 366 pistons are smaller, and possibly lighter. Just wondering.
Hey guys, there's a shop in LA that bought out an old parts store or dealership, he had a shelf of New/old GM 427 cranks. I got one for 250, Ron Sporl performance 504-279-2460, don't know if he still has any...
The 366 truck motor used 4 ring pistons which were probably as heavy, if not heavier than the 427 pistons.
My 366 crank ended up needing a small slug of heavy metal installed in the front counter weight to balance out. But then i used longer rods and 454 pistons with a much shorter compression height than your standard extra heavy 427 piston short con rod setup. I also had to use a weighted flex plate because I have a 1-piece rear main seal crank.
