St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have a question about flywheels. I have given thought about running an aluminum flywheel with the LS. I am going to run a bigger cam than the Z06 cam. What drawbacks or advantages are there to running an aluminum flywheel? I am thinking it will help the be more rev friendly.
I just got back from buying an LS6 with auto tranny out of a wrecked (on the side) 02' Camaro SS 35th Ani car. It's kind of dirty and has 95 k on it. Paid 2900 and comes with everything I asked for. I also picked up the dual fans for an extra 100. Not keeping track of costs....don't care....gp
2002 - Wouldn't that be an LS1 same as the 02 Corvette? Just guessing since I own an 02 Vette and my engine is an LS1 - thought the LS6 was newer but then again maybe not - C5 Z06 - was that an LS6?
I thought I corrected that with a later post. You are right, that would be an LS1. The 2002's in the Z28 and Trans-Am all had the LS6 intake and SOME had the LS6 block. If you get lucky, you can find one. I got my numbers backwards and thought I got an LS6 block but I realized later it was an LS1. Only slightly disappointed. Not a whole lot of difference. You can still really crank some HP out of an LS1 with some head porting, cam and exhaust. That's what I'm doing....gp
You're going to be surprised how rev friendly a stock LS1 is. I still recommend the stock LS2 flywheel and LS7 clutch and maybe go with an aluminum drive shaft instead.
Originally Posted by 70 LS1
Cool, Eddie. How soon till parts start hitting the car?
Any idea what valve springs those are? 01 LS6 springs should be blue and 02+ should be yellow.
Jeff, its going to be at least this fall. Well, I did install the oil fill cap. I am not really concerned about the spring color right now, what I am most concerned about is whether or not they are the sodium valves. I plan on installing a set of Comp Cams 915 or 918 springs anyway.
Originally Posted by SuprJames
Are you going to do a cam too?
I want to. Just got to make up my mind on what I want it to do for me. I would like to get around 400 RWHP and TQ. That would be about 150 more HP than I have now at the rear wheels. I don't really care about having a big lope. Just make it run smooth and powerfully.
At least you are getting all the parts ahead of time. When I did mine, it took me a year from the time the engine first dropped into the car until I fired it up the first time. I was a little anxious to say the least. I had the old engine pulled and on a stand before I even knew what I would replace it with.
How do you tell if you have the sodium valves? I guess you could weight them? I'd check over at ls1tech, I'm sure someone over there could just rattle off how many grams they should weigh.
Eddie
Just out of curiosity are you going to use your tremec or are you looking for a modern 6 speed. I guess what I'm asking is can you mount the tremec 5 speed or an older 4 speed to an ls1?
Originally Posted by TTop Tony
Eddie
Hey Tony. Long time. I plan on using the tremec behind the LS motor. From what I understand, you need an extended input bearing and a way to mount the z-bar at the motor side. I am going to order the Z-bar mount from Scoggin Dickey. That will be covered. The stock bellhousing will bolt up to the LS motor. There will be one hole that will not get a bolt in it though. I have not made my mind up on this point yet. I have been thinking about getting a bellhousing from Keisler that will bolt right up to both.
Yes it has been a long time. I still lurk in the c3 section. Glad to see you still hopping up that nice car of yours. If I ever get enough $$ I'm painting mine the same color. With the rising price of gas I was kicking the idea of an ls1 swap but I'm not as brave as you. I was wondering if I could keep the 5 speed thats in the car (Its a richmond not a tremec). That would surely lower the cost of the swap. Didn't think about the z bar though. Hopefully you'll take good notes
