'72 small block. This looks like Bubba. Here are two fuel lines going into the fuel pump. My assembly manual only shows one. The bigger problem is where the hard line is cut and then rubber is used to bridge the gap and connect to the pump. Bad, bad, bad! Without completely re-running the line from the tank, it seems that replacing the rubber with braided lines might be the best fix. But, what's the best way to make the connection from braided to the hard line? I'm also open to any other suggestions that would be better. Thanks!
Those are not the original hose clamps, but that is the way GM ran Corvette fuel lines for many years. Remember, the engine moves on the mounts, so hard lines between the frame and pump would eventually result in fatigue cracks. Hard line from the pump to the carb is another story.
Makes sense. Are the original GM hose clamps any better or just different? I also have a hard line to rubber hose rigged for the carb which I'm changing out to braided all the way.
What carb are you running? For the pump to carb, if it's a q-jet, just buy the solid line. I think midamerica sells em for pretty cheap.
It's the Q-Jet. I bought a solid line from Eckler's which came nowhere near the correct shape or length! Since I didn't open the package for a couple of months, when I tried to return it Eckler's gave me the big SOL. Do you think Mid-America's is better?
That's the way it was done back then. If the original formed "bulbs" are still present on the ends of the tubing there's nothing wrong with the way it is, just change the rubber hose with some good fuel injection hose.
If you want braided hose you can cut the ends of the tubing and install an AN nut and sleeve, then flare them for AN fittings for a complete connection.
Duke94 has the right idea about the rubber lines connecting the steel lines from the tank to the pump. I recently got the molded supply hose which is in the shape of an S from Corvette Central. I didn't see a molded return line in their catalogue. Anyway, the molded hose eliminates the kink in the hose near the pump.
You also have 2 rubber lines that come off the stainless line to the tank as well. The 3/8 hose is the fuel feed to the engine and the 1/4 fuel line is the fuel return.
Be nice to the Metal fuel line. They cannot be replaced with the body on the chassis.
You want the line from the pump to the carb to be steel or [stainless]. Having a pressurized fuel line break in your engine compartment is not a good thing! If one of the flex lines on the pump breaks, it will not be under pressure and it will not get to the headers, etc. to catch fire. Metal braided line on the inlet side of the pump would be an improvement.
