How about a ZZ4 with Dual quads !!!
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
From Sallee Chevrolet's web page !! http://www.sallee-chevrolet.com/Chev...azz4ho350.html
The Nostalgia ZZ4 HO 350 is built around the solid foundation of GMPP's ZZ4 350-cubic-inch High Output Chevrolet small-block V8, part number 24502609.
The ZZ4 350ci High Output Chevrolet foundation is the perfect power plant for many high-performance off-highway applications. The H.O. engine offers outstanding performance at an affordable price. It is a bolt-in replacement for all 265-400ci small-block Chevrolet V8s.
High Output 5.7-liter engines are assembled using brand new, premium quality components. This assembly combines proven small-block components with the latest advances in engine technology, including lightweight aluminum cylinder heads, low-friction hydraulic roller tappets, and hypereutectic (high-silicon) pistons. All H.O. small-blocks are fire-tested and final balanced at the factory to ensure their quality and performance.
A prototype ZZ4 H.O. 350 engine with a Quadrajet carburetor, 1 3/4" headers, and low-restriction mufflers produced 355 horsepower @ 5250 rpm and 405 lb.-ft torque @ 3500 rpm.
The Nostalgia ZZ4 HO 350 builds on this solid, reliable foundation by adding class, beauty, elegance, and a touch of days gone past. Added to this, the Nostalgia ZZ4 HO 350 has all the right parts to make your street rod a true performer. We chose a camshaft combination that gives the lump and exhaust crackle most street rod enthusiast are looking for. With the Nostalgia ZZ4 HO 350's Great looks and great power, what else can you ask for. Now you can double your pleasure with this hot, classy dual four street performer with 375 HP @ 5,700 RPM and 380 ft. lbs. @ 3,800 RPM.
Re: How about a ZZ4 with Dual quads !!! (Vetteboy)
Interesting that they swap the current technology ZZ4 cam for the older ZZZ single pattern cam. Sure it picks up 20 HP but it also drops 20 ft-lbs of torque. Seems like they were going for that lumpy idle factor.
Wonder how it would do with the HOT cam instead?
