GM HEI vs. unilite
Old Jun 25, 2007 | 01:05 AM
bodawg73stingray's Avatar
bodawg73stingray
Cruising
Default GM HEI vs. unilite
I'm actually on the verge of swaping from a GM HEI (in cap coil of a 78) to a mallory 57 series Magnetic Breakerless Ignition. I'm running a hotter coil than the GM in cap but the general opinion seems to be that I'm going to loose some power and response. Does anyone know if I should expect to lose a considerable amount or could I gain some by running the hotter coil?
Old Jun 25, 2007 | 08:34 AM
Big2Bird's Avatar
Big2Bird
The GM HEI is hard to beat. The Unilite is a downgrade in my eyes.
Old Jun 25, 2007 | 09:02 AM
pws69's Avatar
pws69
I have had 2 Unilite distributors fail on me (the module inside died) in the past. Wouldn't get another one.
Old Jun 25, 2007 | 09:36 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
How do you know it's a "hotter" coil? What are the specs versus the stock HEI coil?
Old Jun 25, 2007 | 12:39 PM
lars's Avatar
lars
The "hotter coil" won't gain you anything unless you're running compression levels and rpm so high that you're on the verge of extinguishing the spark.
The type of ignition system you run, whether it be stock points, stock HEI, or one of the aftermarket capacitive discharge systems triggered opticially or magnetically is irrelevant as long as you're getting adequate spark to fire the plugs at the compression and rpm you are running. What is far more important is the timing curve you set up in the system you are running. The timing curve will determine the power and throttle response you get - not the type of trigger device or how "hot" the coil is. I've shown many times that a properly curved old-style points system with a stock coil will grossly out-perform a fancy capacitive discharge system with a "hot" coil if the curve in the aftermarket system is not set up right.
Spend time tuning what you have. The gains will be much more than by simply replacing with other style components.
To GM HEI vs. unilite
