6 speed swap questions..
ok i have decided and am almost there except for a few problesm i am swapping ym wrecked LT1 motor and 6 Speed T56 trans in to my 1977 vette has anyone elses done this that can help me? my camaro was a 1995 z28...can i use the cltuch peadels from the camaro? can i use the hydrolic clutch linkage instaed of mechanicl linkage?....this is were i am stuck the peadels and linkiage and stuff any help please...thanks
Why do you want to change the pedals, I fitted the T56 with the stock pedals and a set of Speed Direct clutch rods no issues at all. Have a look at my website for photo's, hope this helps.
Great looking car, BTW!!!
You would be further ahead to start off with a viper T56, that shifter is easily relocated to the correct position.
The cool part is that when your done, you'll have a double overdrive and low cruising rpm's.
Good Luck.
Richard
Tech Support
I'm using an LT1 T56 too.
it's going in my 82.
here are some pics
the LT1 T56 with slave/master from the f-body.
the yoke and trans mount are from my TH700R4.
because of the weird angle of the master cylinder, I'll use a mc from a 85 one ton truck with custom line. it has a smaller diameter (11/16" instead of 3/4") so it will need more stroke on the pedal.
for the clutch, I'll use a LT4 pull-type pressure plate (original VALEO part) and a McLeod disk.
this is the stock TH700R4 crossmember. the T56 needs to be about 1/2-3/4" lower.
I modified the stock crossmember
here it is... I checked driveline angles within 0.2°.
the trans almost clears the tunnel. I had to slightly massage the tunnel with a hammer and remove a rubber bumper which is mounter on top of the tranny.
I had to cut the tunnel for the shifter too (my vette was an automatic).
the driveshaft is the stock TH700 one.
I still need to measure how far the shifter is from the stock opening in the console. It seems that a 1.5" offset to the front and 1" to the left will be good. I plan to order a McLeod shifter (but I want my shifter centered in the console).
hope this helps...
/Vince
here are some pics
hope this helps...
/Vince
It is looking really nice. You'll be smiling from ear to ear when it's all said and done.
Just so you know, the shifter should be 25.93" back from the block flange(where the bell bolts up) and 2.313" offset towards the drivers side from the centerline of the tunnel.
Hope this helps.
Richard
Could you please tell me the exact thickness of the spacer for the clutch slave cylinder. Mine is missing and i need to make something asap. Thanks
awesome looking project to keep up the good work
Hi folks- I joined this site because my gf's '94 Trans Am GT (1 of 1100), Lt1/T56 always has to be cross-referenced w/a 2000 Vette.when we buy parts.I've owned 4 'Birds, a 69 (326HO/Muncie 3sp), 2 gen III's and a '75 Formula 400) so I like to think I;m not totally ignorant.
The trans doesn't have the clutch slave showing. I need to pull so I can replace clutch, pressure plate, flywheel, etc.I have not been able to drop the trans at all, and can't find the prybar slots.
Any way you fine folks could help is greatly appreciated.
