Desperate for headlight help ... PLEASE
Old Jul 3, 2007 | 10:32 PM
rfhall50's Avatar
rfhall50
Default Desperate for headlight help ... PLEASE
I am in the process of redoing my interior, specifically a dash cap. I was trying to remove the stem from the light switch (by pushing the little button in back) so that I could test fit the cap. When I couldn't get the stem out, I started working on the headlight switch from the left side with the dash pulled partly out. The switch was pushed/pulled several times during the process. Then I noticed light smoke from the area. Suddenly no lights. I checked the fuse box and found the tail light fuse (20A) was blown. Replaced it and tried headlights again. In the mean time I have noticed scourch marks on the plastic connector attached to the headlight switch. When I tried the switch after changing the fuse, it blew the fuse again.
I was wondering if I have cooked the headlight switch. But, would that also cause the 20A fuse to blow ? I read about a ground strap to the headlight switch. I don't see how this would blow a fuse, but who knows. I read that there is a circuit breaker in the headlight switch. Is there anything I should do to this ? Any way to reset it ?
BTW, have never had headlight problems before. I obvisously blew the mission on this one. Replace the headlight switch first ???? Any suggestions are appreciated.
Thanks ...
Bob
Old Jul 3, 2007 | 11:03 PM
RMS73's Avatar
RMS73
Replace the light switch. When you turn on the headlights the tail lights also come on. On my first 73 I had issues with the lights not coming on with the switch pulled out. One day I smelled the burned electrical odor coming from the dash. Killed the battery and pulled the dash, you guessed it, the light switch had a short in. Replaced the switch and no problems. One of the first things I did on my current '73 was to replace the light switch. It was giving me problems, but it was old and I didn't want any problems.
Roger
Old Jul 3, 2007 | 11:06 PM
DARROW's Avatar
DARROW
Default fill out the your info
Thanks ...
Bob
What car do you have what year
Old Jul 4, 2007 | 07:53 AM
rfhall50's Avatar
rfhall50
Default Head LIght Help Needed - UPDATE
Sorry, I forgot to mention is is an '80.
Bob
Old Jul 4, 2007 | 08:06 AM
Duke94's Avatar
Duke94
Helps everyone if you fill out your profile.
Old Jul 4, 2007 | 06:03 PM
SARASOTA SAM's Avatar
SARASOTA SAM
Thanks ...
Bob
I trust you disconected the battery before touching the dash?
Old Jul 11, 2007 | 11:40 AM
rfhall50's Avatar
rfhall50
Unfortunately, I did NOT disconnect the battery before I started. I have, however, learned my lesson. Last night I installed a battery disconnect knife switch.
You can teach an old dog new tricks, but then they are still an old dog !
Bob
To Desperate for headlight help ... PLEASE
