I have looked closely at my 81 front suspension. It seems the A-Arm lower bushings are gone. Top ones appear to be fine but who knows for sure. How much should I expect to pay for a shop to change all the front suspension bushings?
Thanks for the advice. I like to do my own stuff also but when it comes to removing and compressing springs, I would prefer for someone else to do it. I do not have a lift so it is quite difficult for me to spend that much time lying down...Thanks
Broken down like this:
$2398 = 22 HR's Labor @ $109
$199 = Front Suspension Rebuild Kit (Deluxe) from Corvette America
$81 = Front Springs
$62 = Front Shocks
$55 = Shop Supplies
$2,795
$81 = Front Springs
$62 = Front Shocks
$55 = Shop Supplies
$2,795
$397 in parts & $2398 in labor.
Which is why I am doing it myself.
That's way to much money and way to many hours.
We charge $400 to rebuild all 4 a-arms. Powder coat them, new bushings and new ball joints. We charge $200 labor to remove and install the a-arms. $600 plus an alignment.
And they do a beautiful job on the rebuilds...worth driving up there to have them do the rebuild at that price!
Locally I was quoted a labor cost of ~800 to install refurbished parts. The full front end rebuild was about ~1200 if you used the shops parts. This was from a Corvette specialist shop.
Thanks a lot guys...Now I have an idea what to expect for labor charge. I will go to Van steel if I was a bit closer. Should I go with the original rubber kit or the Poly?
I heard poly will squeek a ton. Depends on how much you are going to drive it. if it's a daily driver, maybe consider poly for long lasting wear, if it's a fun pleasure car, I'd go rubber.
I spent 400.00 for a complete rebuild kit and did it myself last winter,saved alot of money and was able to take my time as the weather was not Vette driving weather. Was not difficult at all!
Poly squeaks like crazy if you have ancient bushings or don't grease them properly. The materials technology has changed a lot in the past 25 years. Use the sticky silicone grease, and they're fine.
IMHO, rubber is only good for rotting, deflecting and throwing off alignments. My Jeep is seven years old, and the bushings are already starting to look like crap.
From: Graceland in a Not Correctly Restored Stingray
After reading up a bit on poly bushings, apparently when they start squeaking thay are beginning to bind. Very important to lube the properly with a silicone, synthetic or marine grease that resists wash out. But, it's not that anything is wrong with poly.
Also, poly has a bad rap among some circles as making for a harsh ride. Don't understand this, as I've had poly for years without complaint and recommend them without hesitation to any serious driving enthusiast. You should avoid driving thru pot-holes, anyway.
Rubber bushings rot and allow suspension geometry to move all over the place. For a sports car, I cannot recommend them for anything other than a correct NCRS type resto.
absolutely. If you're going to be that far in it, might as well make it better. I don't know of anyone that's taken their suspension apart and used rubber instead of poly. It's definately on my to-do-list.
Now you know atleast one person...I just had the front end redone a few weeks back and went with rubber under advisement of a local, corvette only repair shop. The squeek scared me away.
Take a screwdriver to your existing rubber bushings and see how oil and other fluids have deteriorated the rubber. You only have to drag the edge of the screwdriver along the rubber and see it peel off. If that doesn't convince you to switch to poly, then nothing will! Proper lube and installation will ensure no squeaks.
Check around, theres a couple of corvette specialty shops down your way. I remember there being one in Hialeah around the Palmetto and 103rd and theres one in Ft. Lauderdale-ish
also check with forum member speedE55 he has a few corvettes he's restoring. I'm sure he can point in the right direction down there.
I understand that you don't have a lift, but a good set of jack stands, a rented spring compressor, and you're on your way.. Shoot, if you were anywhere near me I'd do it for you for a 6pack of Newcastle! Its really not that difficult. I started mine at lunchtime and was cleaned up and finished for dinner. As for the Poly / Rubber debate- I went poly. Like others have already said, if they are installed with lots of that snotty grease, they won't squeek. There's NO WAY I would pay those prices for that job. (OK, lets be fair- maybe a 12pack of Newcastle )
I have been looking around for this myself. Contacted two shops here in central California and the quotes were $575 and $600 for labor and alignment. I would have to supply all the parts, but that was a complete rebuild, ball joints uppper/lower, bushings, tr ends, coils and idler arm.
Never done the job myself, but those coils are the only part that bothers me.
I put poly bushings in A-arms this past winter and replaced all front end components. Dont have any squeeks yet, but I only have about 650 miles on it so far. One area I would be carful w/is choosing your coil spring rate. I went w/ 550lb coils from VB&P. I love the way the car sits now. Not down in the weeds, but much lower than before. I have a ZZ4 and also run an aluminum radiator, aluminum water pump and headers. The ride/front end is stiff to say the least. I use a 330lb glass spring in the rear. The front pounds over any small potholes/cracks in road. The rear seems fine. I now pay more attention to what roads I drive the car on. The VB&P's 460 lb coils, even w/ a half coil cut off to lower the car, might be a better way to go for softer ride. Food for thought.
