73 lower ball joints
Old Aug 1, 2007 | 09:42 PM
troythefixer's Avatar
troythefixer
Default 73 lower ball joints
tell me what the secret is to getting the lower ball joints to separate. Am I going to have to get my tanks filled and heat them. I'm getting tired of beating on them. Give me some advice. tks Troy
Old Aug 1, 2007 | 09:45 PM
Durango_Boy's Avatar
Durango_Boy
Are you using a pickle fork? They are cheap at most parts stores and some even rent them for free.
Get it in there good, and give it a few good whacks. Also, tap the bulk of the rod end with the hammer...sometimes that impact will help shuttle the stud out.
Old Aug 1, 2007 | 09:58 PM
troythefixer
yea i'm using a fork and 3 pound hammer, i thinkk i'm going to get a 12 pound sledge hammer tomorrow. troy
Old Aug 1, 2007 | 11:13 PM
SIXFOOTER's Avatar
SIXFOOTER
Just get annother 3lb hammer, hold one hard against one side of the spindle next to the ball joint shaft and smak the other side with the other hammer, once or twice and it will fall apart. Use gloves and watch your fingers
Old Aug 2, 2007 | 12:54 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
You can buy a special puller tool from snap on tools that will press the buggers out. great tool. see your local snap-on dealer.
Old Aug 2, 2007 | 10:10 AM
weimer20's Avatar
weimer20
Picklefork on a pneumatic air hammer is really fast and easy but you gotta have the equipment.
Old Aug 2, 2007 | 02:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Pickle forks are junk. Use the right tool, it looks like an "H" with a fork at one end and a bolt running between the legs of the "H" on the other. JC Whitney sells it for about $20.
Old Aug 2, 2007 | 03:50 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I had trouble getting mine out too. I believe I used a ball joint and a tie rod pickle fork at the same time from opposite directions.
Old Aug 2, 2007 | 08:10 PM
chris73cpe's Avatar
chris73cpe
pickle forks work great if you don't care about destroying the ball joint. 4lb hammer and a few solid hits and out they come.
Old Aug 2, 2007 | 09:59 PM
72LS1Vette's Avatar
72LS1Vette
I couldn't get mine loose until I took off the lower arm, placed it securely on the floor, and whacked it a couple of times with an 8 lb sledge hammer.
Rick B.
Old Aug 2, 2007 | 10:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Every ball-jointed axle I've ever worked on has had at least one joint that a pickle fork wouldn't bust loose. The "H" tool has never failed.
Old Aug 2, 2007 | 11:39 PM
...Roger...'s Avatar
...Roger...
Is your jack under the a-arm?
If your stands are under the frame and the a-arm is hanging you will never get it to seperate.The spring is just forcing it back together unless the upper is already loose.
To 73 lower ball joints
