Th400 swap to Th200-4r?
Hi,
has anybody swapped out a th400 for a Th200-4r? Apparently a new yoke is needed, but does the stock Th400 driveshaft need to be modified? If it does, would it make sense to just use a yoke & driveshaft from a C3 running a th350?
TIA
TIA
Yes, I believe you would need a TH350 driveshaft or modify the original. The yoke is the same as muncie 4-sp, TH350, or 700R4 for a C3. You need 1 with straps or u-bolts so it will go in without taking the car apart.
Wow! Thanks for the quick replies The Th400 yoke, I've been told, has a different number of splines than a th200's, but when I fitted my Th200 the stock Th350 yoke slid right in & there were no driveshaft length problems. So it looks as if asking a local Vette specialist to supply a used yoke & driveshaft out of a Th350 equipped Vette would probably be the simplest/quickest solution?
Mark, good point, no straps or U bolts would make it a bit tricky to get in/out Are U bolts stronger than straps on the UJ's, or are they about the same (this is going behind a big block)?
Is the driveshaft used in a BB stronger than that used in a SB, or are there any other potential "gotchas" with this swap that anybody can think of?
The driveshaft you have will work without any changes. The front universal needs to be changed to the style that fits the new yoke. This is a self item at most parts stores.
200-4R repalced TH400 in my 73
When I did this swap, I re-used my driveshaft, and bought a new front yoke and combination u-joint.
While you have the driveshaft out, that's a great time to have it balanced
I just finished puting a 200R4 in my 80. Bow Tie Overdrives makes a nice crossmember to make the swap easie, it just bolts right up. I am using the yoke from the original th350c and the drive shaft.
Thanks for the replies, they've cleared up some confusion It'll probably be a Level 3 BTO unit that gets put in there so (hopefully) the HP won't be a problem.
Dave, I've got one of those x-members in my '81. It's easy to fit a true dual system with it fitted The reason I posted this question was because the current trans is a Th400 and, while I know the Th350 swap doesn't give any driveshaft/yoke issues, I didn't know if it was the same for a Th400.
