Which holes???
Old Sep 4, 2007 | 11:18 AM
sly vette's Avatar
sly vette
Default Which holes???
I have a '69 without power steering and I would like to know which holes on the spindle do the tie rod ends go in...The inner or outer holes??
And what are the consequences of having them in the wrong holes??
Why are there 2 holes???
Thanks,
Mark
Old Sep 4, 2007 | 11:21 AM
SIXFOOTER's Avatar
SIXFOOTER
Outter hole for manual, inner for power. Outter gives more leverage for manual steering
Old Sep 4, 2007 | 11:35 AM
sly vette's Avatar
sly vette
So if I have strong arms I can reduce the travel from lock to lock???
Mark
Old Sep 4, 2007 | 12:08 PM
SIXFOOTER's Avatar
SIXFOOTER
Yes, just take a look at the tie rods, make sure they don't bind up under there
Old Sep 4, 2007 | 12:15 PM
...Roger...'s Avatar
...Roger...
I did my 66 that way and had no problems but I have heard that the C3s have a different pitman arm for some reason.You might want to check that out and make sure it wont rub on anything when you move them.
Old Sep 4, 2007 | 12:24 PM
sly vette's Avatar
sly vette
Thanks. I will check everything mentioned and let you know how I feel about the new setup.
Old Sep 4, 2007 | 01:19 PM
sly vette's Avatar
sly vette
Will I need to get a new alignment???
Old Sep 4, 2007 | 01:44 PM
...Roger...
You'll have to have the toe-in set if you dont have a way to do it yourself.
To Which holes???
