Oil smoke
here's a pic, vent on righthandside of rocker cover
cheers
dave
On the driver's side is a PCV valve in the valve cover, attached to a vacuum line attached to the tree on the manifold.
Pull that PCV valve out, and see if it rattles when you shake it. If not, spray it with some brake parts cleaner to help free it up.
Buy some Sea Foam next time you are at an Autozone or Oreilly and when you have that PCV vacuum line disconnected, slowly suck up some Sea foam through it.
It should suck it up quick and the engine idle will speed up so go slow with it. It'll clean everything out. If you can, suck a little bit of Sea Foam through all the vacuum tubes leading into the carb.
After you do that see if that smoke goes away. You may have bad valve guides.
Oh, that silver thing is an "oil beather cap". good luck
does it need a vent there?, and pcv is on the other rocker cover, does that make any difference?
cheers
dave
thoughts?
dave
DB: Daves's from the uk,
I'm not sure but i dont think we have Autozone or Oreilly in the Uk yet.
The silver oil cap is a vent. It should allow the engine to breath..the PVC valve sucks vapors out of the crankcase and runs them back thru the base of the carb. If you look at the engine from the front of the car, just in back of the carb is a line running off to the right,makes an
90*elbow,into the valve cover. Simply pull it out. Shake it. It should have a rattle. If it doesnt,replace it,their cheap. Vapors should not be comming out of the oil cap over on the left side valve cover. If the PVC is good, then that might very well be a sign of a tired engine. Dont worry,its not about to blow up or break, its just getting loose. Perhaps this winter you might think about a rebuild. Before I did that tho, I would run a compression test on each cylinder to find out more info. Heck, it might just need a valve job or less.Keep an eye out for the helicopter in my avatar..its near Blackpool/Whisem. I was over there in Jan/feb flying on it with BBC filming the event,then showing it on "Inside Out" NW edition. best of luck.
You'll also get some smoke if the PCV system isn't working correctly.
The important thing here is "idle", as that is when you have the deepest manifold vacuum because the throttle's shut. And that vacuum likes to suck oil down past worn guides and into the cylinder! Another sign is a puff of smoke on startup, after you switch it off hot and leave it for a few hours. This comes about because the oil seeps down past the guides onto the backs of the valves or into the cylinder, then burns off when you start her up. Pretty typical of SBCs with some miles, I understand. Mine certainly does it! (Quite embarrasing in the pub carpark!) but valve guide wear isn't really the end of the world. Ring wear's a bit more serious though.
What state's your oil in? If it needs changing that might exacerbate the problem with the smoky breather, but having said that even changing it is only really a band-aid on the deeper problem. A bit of smoke's not the end of the world on an old engine - just exactly how much are we talking? Is it enough to show in a picture that you could post?
Someone may have said it before but the best way really know what state your motor's in is to do a compression test (HOT, throttle wide open). One of the most fundamental measures of engine health. If you ain't got no compression you ain't got no engine.
I noticed there is not a baffle underneath silver vent, would that make a difference?
Lars - best thing you could do is send me over a new big block engine, and come install for me, I'm buying the beers!
cheers
dave
Some great information in this thread and to sum it up going from easy to hard or cheap to expensive as the case may be.
check
1) PCV for correct operation
2) Valve stem seals for wear
3) do a cylinder leak down test
4) Pull the heads and check the valves and upper cylinders and also the cylinder head gaskets.
The 3rd option will give you a very good idea what shape the engine is in over all.
Lars really has some awesome info in his post.
Andrew
when the manifold vacuum was high. The PCV isn't intended to put the crankcase at a really deep vacuum, just fractional psi negative pressure, enough to keep the blowby gases re-cicrulating. Hence the fairly low restriction pipe running from the stock air box down to the p/s rocker cover, to bleed some air in.Dave, grab a compression gauge from Halfords mate, (or somewhere else that does tools and isn't as pricey!) and "follow the instructions on the box". You can tell a lot about the health of the engine with it. A leak down test, as VetteThunder1 mentioned, is also a good test but requires a bit more faffing about and other equipment (air line and gauges etc), so for the moment a compression test would be a good start.
By the look of that engine bay I think you've got all sorts of fun ahead of you
