I have problems getting it up...
Old Sep 7, 2007 | 03:44 PM
79VetOwner's Avatar
79VetOwner
Default I have problems getting it up...
I hooked up a new vacuum line all the way around. Headlights to carb and to switch and etc. Hooked it all up according to the headlight vacuum diagram I got from corvette-101.com.
When I pull the vacuum switch to get the headlights up they just sit there, but when I get alot of vacuum built up (about 4000 rpm) the DS headlight goes up on its own without me pulling the switch. I try to pull the switch and make the other light go up but nothing happens. Then I close the switch but the DS light stays up, I cant get it to go down unless I do it manually.
I know its all vacuum problems but can anyone help me out? I hooked it all up right and thought that would be good enough although it never is.
Old Sep 7, 2007 | 03:59 PM
kayosnes's Avatar
kayosnes
Could be the headlight actuator.
if not. try viagra
Old Sep 7, 2007 | 04:30 PM
2armor's Avatar
2armor
if not. try viagra
Its expensive for those actuators and other headlight parts. I know some guys who just open them manually or leave them up all the time.
PINA but they are only weekend warriors, not daily drivers..
Good luck!
Old Sep 7, 2007 | 04:37 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
You say you hooked it up as per the diagram on corvette101.
There is a mistake on that diagram.
You will find the revised diagram in this thread.
http://forums.corvetteforum.com/show....php?t=1806732
Old Sep 7, 2007 | 04:39 PM
73C3's Avatar
73C3
Quick Check: Attach to free hoses to actuator. Blow in one and the headlight should move in one direction, blow in the other and it should have the opposite effect. Normally this is done with vacuum which would have the opposite actuation.
If you have no resistance and actuation in one direction, you might have a bad "witches hat" seal on around the actuator lever. This is under the acordian type dust boot.
Also I think I remember a problem with the diagram around the switch area. I'm not sure if it's that particular diagram or another. Do a search on the forum.
Old Sep 7, 2007 | 05:00 PM
weimer20's Avatar
weimer20
Old Sep 7, 2007 | 05:24 PM
79VetOwner's Avatar
79VetOwner
Awesome, I will check it out.
I will try that.
Old Sep 7, 2007 | 11:06 PM
martinsw's Avatar
martinsw
Got a GREAT laugh out of this post title ....There are also inexpensive new seals and rubber boots (Dr rebuild or others) that fixes a problem in one direction but not the other. I have lucked out and all of my headlight up/down issues have been fixed by putting in these new seal/boot repair kits (much less expensive than new actuators).
Old Sep 8, 2007 | 01:08 PM
79VetOwner's Avatar
79VetOwner
Glad you liked the title, I figured it would get me some looks
I think I will have to try the seals youre talking about, everyone so far gave great suggestions that I have now tried but to no avail. I will look into the seals/rebuild kits.
Thanks everyone.
To I have problems getting it up...
