Small Block oil Pump Question
Old Oct 22, 2007 | 12:54 PM
J Koehler's Avatar
J Koehler
Default Small Block oil Pump Question
I have a 69 small block 350-350. I bought a high pressure oil pump for the rebuild. Will the High pressure pump give me problems? Will there there be to much oil in the upper part of the block? The pump was puchased from Corvette America.
Old Oct 22, 2007 | 01:13 PM
2armor's Avatar
2armor
I find they require a little more hp to turn. Just as good flow / pressure can be had with a std pump with the proper porting / polishing with a die grinder at the Rear main caps / oil pump union. They tend to be the largest contributor to this oil flow restriction due to oil paths being tight and rough.
Old Oct 22, 2007 | 02:12 PM
billla's Avatar
billla
St. Jude Donor '14
High pressure or high volume? The high-pressure pump is fine - the stock Z-28 pump is high pressure. High volume I'm not a big fan of if the clearances are factory - you end up with a bunch of bypass going back into the pan and as noted it takes more HP to drive.
Old Oct 22, 2007 | 02:26 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
High pressure pumps require no more effort to turn, it's the longer gears in the high volume pumps that are harder to turn.
No problems with too much oil upstairs running a hp pump.
Old Oct 22, 2007 | 02:28 PM
vettfixr's Avatar
vettfixr
I've been running a high pressure/high volumn pump in my L48 for about 5 years now and never had a problem. Its nice to see oil pressure on the gauge.
J Koehler's Avatar
J Koehler
Thanks for the info. It is High pressure and I am not to concerned about the HP since it will not be used for racing.
Old Oct 22, 2007 | 03:45 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
This comes up all the time, and I am amazed at the take so many have on it. Besides wasting power, excessive oil pressure puts additional heat in the oil and increases oil pump drive component wear (that wasted power doesn't just magically disappear), not to mention causing oil to bypass the filter more often. According to Smokey Yunick (who among us is qualified to question his wisdom?) anything very much more than 10psi/1000rpm (hot) is excessive (racing, or no). So, insurance it's not.
Old Oct 22, 2007 | 04:05 PM
billla's Avatar
billla
St. Jude Donor '14
No pushback on the high pressure overall, but we need to differentiate just a bit. High VOLUME is a structurally different pump. High PRESSURE is controlled by a spring in bypass. Almost all of the high pressure pumps come with a second spring for lower pressure if needed.
It's worthy of note that although no one would ever question The Great One (Smokey), times change and for example the LT1/LT4 pump is a high-pressure pump.
I think the nut here is that HV is not required, and you should run a pressure that's appropriate to the use of the engine.
Old Oct 22, 2007 | 04:08 PM
TheSkunkWorks
My point, exactly.
Old Oct 22, 2007 | 05:19 PM
hugie82's Avatar
hugie82
RUN THE DAM PUMP!!! You have it use it. The 3 or 4 horse power you lost, will never be noticed. Pumping all the oil to your heads? Only if you drive a 4500 rpms for 1/2 hour and your drain backs are clogged. The Only precaution I would take, is buy a oil pump drive with a steel collar (SUMMITRACING $10.00) and warm the engine up before REVVVVING AND ENJOY!!!
Old Oct 22, 2007 | 05:28 PM
Stroker-427's Avatar
Stroker-427
Default Pressure
I don't think that a higher oil pressure than stock will come for free !!!!
More power is needed to produce more pressure, be shure!
Tha main concern for higher pressure is the scattering of the igniction.... as you know the oil pump is driven via the distributor shaft and a bigger load will produce more timing oscillation.
The small-block pump have 7 teeth gears wich are quite big, producing a sensible pulsation of load to the shaft.
The Big-block pump have 11 teeth gears and a more smooth rotation.
Specially if you have rebuilt your engine with stock timing set (nylon camshaft gear) I really don't think the HP pump is a good move............. unless you have too much clearance in main and rod bearings..... in wich case you will need an high volume pump!
Just my two cents...
Old Oct 22, 2007 | 05:48 PM
hugie82's Avatar
hugie82
Do they still make a nylon timing gear?
Old Oct 23, 2007 | 09:00 AM
2armor's Avatar
2armor
J, did you learn anything or open up a can-o-worms?
Lots of good point of views, I guess I'll depend on what your working with in the big picture. Oh yeah, run a good / long oil filters too, little less oil by-pass on cold starts..
To Small Block oil Pump Question
