how much vaccum ?
Old Oct 31, 2007 | 12:39 PM
Kev82vette's Avatar
Kev82vette
Default how much vaccum ?
How much vaccum should I have while idiling? 290hp 350 Chevrolet crate engine. Edelbrock 600cfm, weiand intake, cam specs-222/222 and .450 intake / .460 exhaust.
Would the cam make the vaccum gauge needle move any?
Old Oct 31, 2007 | 01:38 PM
cam99's Avatar
cam99
It all depends on the cams LSA. Yes the cam is a big factor in vacuum.
I have a huge solid lifter cam and I have little vacuum, I had to use a vacuum canister to store some vacuum so my power brakes could still work. I get a few pumps of the brakes while the engine is at idle.
You can probably look up specs for a stock cam and compare to what you have.
Old Oct 31, 2007 | 03:11 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
I figure you should have at least 12-14. It is normal for the gauge to move with a cam that has higher than stock duration.
Old Oct 31, 2007 | 03:46 PM
Gordonm's Avatar
Gordonm
That is a pretty mild cam. I would expect 14 to 18 degrees depending on timing. I have about 8 to 9 degrees with a duration of 252/260 @ .050 in a 385 ci.
To how much vaccum ?
