Accel DFI Gen VII installation – A few Qs
Hello
I am about to start my DFI installation and I was wondering where you guys do place the ECU and how do you route the main harness into the cabin? I guess it will be a lot easier to route all the wires before the new engine goes into the car again.
Thanks and greetings from Denmark
Regards
Karsten
Regards
Karsten
CI 5 & 8 Veteran
I mounted the ECU behind the map pocket right hand lower dash. and routed the main part of the harness behind the the defrost air duct to the large existing hole on the driver side firewall just left of the engine. Some of the wiring used for fuel pump, knock sensor, and grounds were routed out the passenger firewall above the carpet line. I started with the un-terminated harness and custom built and routed it to minimize unsightly bundles.
Bullshark
Bullshark
Thanks a lot for the feedback, which is the same spot for the ECU that I’m looking at now. Concerning the main harness, are you talking about the hole in the bulkhead that the clutch linkage normally pass through at the driver’s side – mine is a manual and I can’t find a big hole like you are mentioning?
Regards
Karsten
Regards
Karsten
CI 5 & 8 Veteran
No, It's the one that has a big rubber grommet to the right of the clutch. It angles toward the engine. My memory is vague but I think the speedo cable and/or vacuum hose goes through also? Remember, I configured my own harness so I was able to get it small in diameter using the nylon cable shield we use on military type cables rather than that big bulky plastic accordion crap.
Bullshark
Bullshark
I'm in the process of installing a Holley 950 throttle body injection. I mounted the ECU in the storage compartment behind the passenger seat. I had to extend the tbi harness (the part with the throttle position sensor, the idle air compensator, and injector wires) by two feet. Lots of soldering. Then I ran the harness from the storage compartment thru the trans tunnel following the battery cable route.
Bee Jay
Bee Jay
My engine and gen7 unit are at Competition Marine in St. Louis for dyno tuning as we speak( thanks Bullshark ). I will post pics of the entire installation when I get it back in a couple of days.
Indeed looking forward to see these pictures, I intend to do the same as Bullshark and route some of the main harness out in front of the driver and the other part below the heater core where I will drill a new hole for the rubber grommet.
My harness is not long enough to place it behind the passenger seat and I don't want to start cutting/soldering now, so the ECU has to go where Bullshark installed it.
Another question, I intend to skip the provided Narrow band and go with my Innovate LC wide band from the beginning, how have you spliced the WB signal wire into the ACCEL harness? The instructions does not say how to integrate the 0 - 5 V signal coming from the WB but I can see the possibility to switch between the HEGO end UEGO in the Callmap software.
Thanks in advance and regards from Denmark
Karsten
Thanks for all the replies
I am using the Accel wideband. It plugs directly in to the HEGO plug on the harness. Look at the harness schematic in Calmap and you will see that the Hego connector has power as well as signal wiring. You will probably have to modify your harness or get an adapter harness of some sort. I am not sure what connection the Innovate sensor has.
My ECU is going very close to the location chosen by Bullshark but my heater is removed so I have more room. I am using the opening where the vacumm tubing passed through the firewall.
CI 5 & 8 Veteran
Hello
Karsten
Karsten
Bullshark
Thanks Bullshark
I do have the Accel main harness and as you described, it sounds like quite an easy job. I have done quite a few stand-alones in the past and all of them had a separate channel for WB/NB. Not much info about this topic in the Accel install papers.
So all the so-called "Sensor return" wires are simply a balanced system ground?
What I'm missing is the possibility to integrate 2 WB/NB channels, it is always nice to either have a narrow band you can compare your wide band to (at stoic) or have separate readings for the left/right bank.
Yet again thanks for all the good replies
Regards
Karsten
Regards
Karsten
CI 5 & 8 Veteran
Karsten
Accel has the single HEGO/UEGO input and is setup/programed in the Calmap software application. There are some dual A/F meters that can average the two sensors or configure as narrow band if desired. I am thinking of the FAST A/F meter I think.
Bullshark
Bullshark
If you use the accel wideband kit you will have another ecm to mount but you get dual sensors with this setup. Mine is a single sensor wideband from accel. (dual was just coming out when I got mine)
-Justin
-Justin
Is that a dual sync distributor? And what are you other guys running for a dist. I am running an HEI batch fire right now but want to go to a non-MSD box dual sync in order to run sequential. Anybody using this setup right now?
-Justin
-Justin
I mounted my ECU behind the right dash panel also. The harness is routed through the firewall just to the right of the dizzy and sealed with a large grommet.
Yes, it is a dual sync on my engine, it is simply a dual trigger for the cam/crank so you will need some sort of ignition box to run this setup. I'm going to use a MSD 6A box for my DFI.
Regards
Karsten
Karsten,
I mounted mine behind the passenger side dash as well. I'm not a "purist" so I drill two holes (below the heater core I believe). The wiring routed pretty well from there.
I was using an MSD tach drive distributor, but I was having issues during cranking, so I bought an Accel Dual Sync distributor. I'm told that the trigger electronics that MSD uses don't play well with the Gen 7. It should show up tomorrow. I'll be using the Dual Sync with an MSD 6T box.
Bullshark:
I tried using my LM-1 with the Gen 7, but the O2 readings on the DFI screen don't match the LM-1 readings. What voltage output setting did you use for the LM-1?
Thanks,
Bob
Bullshark:
Thanks,
Bob
accel, band, c3, connectors, corvette, dfi, fuel, gen, installation, installers, management, o2, pictures, schematic, tbi, wide, wiring
