rag joint rebuild
Old Feb 26, 2008 | 04:30 PM
Joe45's Avatar
Joe45
Default rag joint rebuild
Have been reading posts on the subject, bought a kit just to see the replacement parts.
Questions:
1) If I machine up my own replacement pins to match the factory ones and have them peened over like the originals using the rubber replacement disc should I be OK? (kit pins/bolts are not correct dimensionally)
2) Should the pins be heat treated (case hardened) or is a std. carbon steel ok to use?
I would like to rebuild my original unit vs. the price of a new one. I have access to CNC lathes, peening machines and/or a press to hit the end.
Old Feb 26, 2008 | 05:12 PM
GTR1999's Avatar
GTR1999
Joe you're better off dropping the $100 for the GM rag. The material used is superior the kits, not just the bolts.
Old Feb 26, 2008 | 05:34 PM
Jim Shea's Avatar
Jim Shea
Gary,
You got there first.
Jim
PS There were two different rubber and cotton cloth laminated discs. Those with manual steering (and all Corvettes) had 7 laminations. So the disc was nearly all cloth with a little neoprene rubber in between holding it together. It was quite stiff for better handling and road feel.
Those for power steering applications had only 4 laminations. Therefore, more rubber and less cloth. This disc isolated the hydraulic noises from the gear valve. It also absorbed road shocks and inputs better than the manual steering disc.
Both discs were the same thickness (0.38 inch as I recall).
Both discs had metal screening molded into the face of the disc to pass horn relay current through the flexible coupling unit, down through the steering gear into the chassis.
All rebuild kits that I have seen were always 4 ply not 7. And none featured any method of providing a ground path.
I am quite sure that the GM stop pins were not hardened. They were probably cold formed so the surface was work hardened. But there was no heat treatment.
Old Feb 26, 2008 | 05:46 PM
stinger12's Avatar
stinger12
Get the GM rag - I fell for the rebuild kit as well and was very disappointed. I got a GM rag from a forum member, it is much better quality. Do it right - get the GM one.
Old Feb 26, 2008 | 07:06 PM
Joe45's Avatar
Joe45
Jim,Gary & Stinger,
Let me first say I totally respect your feedback,guidance & experience. I follow/read your posts regularly. Thank you. I will take your advise and get a GM joint. I am also curious by nature... I am going to play around with the pins, riveting process etc. Having access to machines and processes just makes it fun. Thanks again for your advice!
Respectively,
Joe
Old Feb 26, 2008 | 08:14 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Jim,
Do you have the part number for the joint for a 1975 with power steering?
Old Feb 26, 2008 | 08:18 PM
GTR1999's Avatar
GTR1999
There is only one rag for L69-82 doesn't matter if it's PS or manual.
one for the 67-e69 and 2 for the 63-66 std or tele column.
The 67-82 are still avail the early ones discontinued a long time now.
To rag joint rebuild
