Vacuum Advance Can
The fix for me was replacing the throttle base with a Quick Fuel billet base. The plates are not drilled,but the base is set up for four corner idle.(My orginal base was two corner.) I also replaced the idle feed restrictors to .035's and idle air bleeds to 70's front and rear. This worked. Nothing else I had tried previously did.
Now I'm not saying this is the magic solution,but if your 850 is already four corner idle, I'd try swapping out idle feed restrictors and air bleeds. For a couple bucks, you may fix the problem.
As it stands I have 8-9 inches of vacuum in gear, idling at 1000.(406 with 254@.050 cam)
I am getting 8" at 1000 with no load in neutral. I wonder if I have a problem or if that is normal for the size cam. I had thought about the locked timing, but I was concerned about pinging if I happened to lug the engine around 2000 RPM.
I looked at the plugs today to see how rich or lean I might be running and posted a different problem.
I want to run with locked out timing for a while, till I'm able to fine tune the carb idle, then I might try to go back to an advance of sorts. This is the biggest cam I've tried to date, so I really had no clue where to start tuning. It's all related. Carb idle vacuum,timing,timing, carb vacuum......
Good luck.
I'd give them a call and they will be able to help I'm sure.
At one point before I went with all the billet parts, I hand drilled the idle feed restrictor to .036 on the stock Holley metering block, and it almost worked. At the time the baseplate was stock,except for the holes in the throttle plates I drilled.Maybe if I went bigger it would have worked, I don't know.
These are the metering blocks. Both primary and secondary blocks have the idle mix adjustment screws, but the secondary block has no power valve provision.
I just had a thought you might want to try. With the engine running at idle,when it starts for stall,try spraying gas into the carb using a plant mister or some sort of spray bottle. Don't touch the throttle,just spray. If it doesn't stall, wouldn't that prove it's carb idle tune,instead of timing?
You can always adjust them back. Been Their, Done That
Trust me your car will idle
