75 Tach Wiring Question
Old May 23, 2008 | 11:38 PM
scottmtp's Avatar
scottmtp
4th Gear
Default 75 Tach Wiring Question
I have a Tach for a 75 vette that I want to put in my 73 which the previous owner upgraded to an HEI distributor without the Tach Drive. As I look at the back of the Tach there are three electrical connectors....two connectors on top and next to each other and one connector below the two. I'm assuming that one connector is for signal, one for +12v and one grnd.....can someone tell me which connector does what. I've tried looking at the circuit board but can't figure it out.
Thanks in advance!!!!
Old May 24, 2008 | 03:26 AM
Theiskell's Avatar
Theiskell
Try a search on tach conversion, lots of help there I have done the conversion its not bad, one wire to 12V one to ground and one to your coil, but I cant remember the order
Old May 24, 2008 | 07:00 PM
yellow-fever's Avatar
yellow-fever
I have also considered doing this conversion on my 74. I found 2 tachs from 75 Vettes on Ebay but it looks like the numbers are slightly different in style on the 75 electronic tach than on my 74. Is this true? For those of you with 74 and earlier Vettes that have done this conversion, how well do the numbers and letters match up between your 73/74 speedo and the 75 tach?
Old May 24, 2008 | 07:45 PM
carriljc's Avatar
carriljc
Default I've got a picture here for you....
sure hope this shows up....you can see the layout of the terminals. It's an old terminal board that I kept around when I installed a Elec Tach in my 68.
.....I would guess the arrangement is the same for 75, 76, and 77.....I didn't have the connector so I just used female terminal connectors on mine...haven't had a problem and it's been about 5 years.
I don't know how to post a picture directly so it shows up here.
Last edited by carriljc; May 24, 2008 at 07:52 PM. Reason: added last comment about posting pic directly
Old May 24, 2008 | 07:50 PM
'75's Avatar
'75
Just roll your mouse over the IMG code and click it, it will say copied, then click and paste it into your post.
Old May 24, 2008 | 07:55 PM
carriljc's Avatar
carriljc
Default Thanks Aktbird....
I was glad when I learned to add the link ...and I'm happier now. appreciate the lesson
Old May 26, 2008 | 12:04 PM
scottmtp's Avatar
scottmtp
4th Gear
Gents,
A picture is worth a thousand words and this one fixed my problem. I wired in the Tach per the picture and it works like a champ.
Thanks for all your help!!!
To 75 Tach Wiring Question
