Need help flushing engine block
Old Jun 1, 2008 | 07:01 PM
VettAgra's Avatar
VettAgra
Default Need help flushing engine block
I have the radiator out to be repaired and have decided this would be a good time to go serpentine and e-fans. While at all this, I found my harmonic balancer to be bad. Since I need balancer and reverse rotation water pump, I also bought new Cloyes timing chain (while Im there repair).
Now, I want to clean out engine block and heater core if possible w/o radiator in car. How can I go about this. Thanks
Keivn
Old Jun 1, 2008 | 07:29 PM
BarryK's Avatar
BarryK
open the drain plugs on the lower part of the block to drain out the remaining old coolant still left in the motor. There is probably 1-2 gallons left in there.
Old Jun 1, 2008 | 07:51 PM
A88FXRS's Avatar
A88FXRS
should be plugs in the block between the middle two cylinders just above oil pan. you can leave freeze plugs in.
Old Jun 1, 2008 | 08:40 PM
VettAgra's Avatar
VettAgra
That sounds easy enough. Should I use some sort of flush or just hose it out?
Old Jun 1, 2008 | 10:15 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Be very cautious using the commercial flushes. Very often all kinds of leaks start soon after. Washing away all that scale and rust often exposes weak spots in freeze plugs etc.
JIM
Old Jun 2, 2008 | 10:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, remove the drain plugs, 1 to a side, and don't get involved with the freeze plugs.
Old Jun 2, 2008 | 01:10 PM
BarryK's Avatar
BarryK
opps, don't know what I was thinking while I was typing, I DID mean to say the drain plugs (not freeze plugs) on the lower portion of the block.
That's what's nice about this place, you make a mistake and someone, if not multiple people will chime in and correct you........
Think I'll edit my other post now...........
Old Jun 2, 2008 | 01:22 PM
Jud Chapin's Avatar
Jud Chapin
Yeah, watch it BarryK.
Old Jun 2, 2008 | 01:33 PM
BarryK's Avatar
BarryK
sorry, I'll try to be more careful
walking away now hanging head in shame
Old Jun 2, 2008 | 01:55 PM
SH-60B's Avatar
SH-60B
I hosed mine out from different ways to try and get the sediment out. Flushed thru the w/pump holes out the drain holes and vice versa, flushed out the h/core both ways.
Old Jun 2, 2008 | 07:06 PM
VettAgra's Avatar
VettAgra
Thats what I was thinking, just needed someone else to tell me.
Thanks for the feedback everyone!
Old Jun 2, 2008 | 11:19 PM
AB73's Avatar
AB73
Default Just knowledge
What has been suggested so far should do all you want. However, as the Forum is a place for knowledge sharing. It was suggested to me a while ago that introducing air in to the flushing water stream would increase the flush effect. I used this set up for another purpose and found that the combination of water and air did increase the scour effect.
For what its worth.
Tony
Old Jun 2, 2008 | 11:21 PM
72-LT1's Avatar
72-LT1
I never new there were plugs in the block, are they like pipe fittings?Anyone have a picture of the plugs?
I still have a lot to put back together and was thinking of how to flush it out as well. If you pull both sides will it flush out the other side?
Sure can learn alot from you guys.
Old Jun 3, 2008 | 06:56 AM
SH-60B's Avatar
SH-60B
Yes, they are simply pipe plugs. Each plug only drains the side it's on. No pic but they are in the middle of the block just above the oil pan rail like A88FXRS said.
Old Jun 3, 2008 | 09:06 AM
BarryK's Avatar
BarryK
Old Jun 3, 2008 | 12:56 PM
72-LT1's Avatar
72-LT1
Cool, thanks Barry.
Does anyone suspect there might be a problem getting them out? rusted in palce etc?
Old Jun 3, 2008 | 08:34 PM
moosie982's Avatar
moosie982
Cool, thanks Barry.
They can be very stubborn, proceed with caution. Peace,,,Moosie
Old Jun 3, 2008 | 11:19 PM
birdsmith's Avatar
birdsmith
Use a six-point socket- if you try it with a twelve-point you'll most likely round off those plugs.
To Need help flushing engine block
