? for the supercharger guys
I dont know the engine but there is a crankcase vent in the block by the distributor. Ventilation on supercharged engines should not be anymore necessary than a normally aspirated engine. Alternatives are to place breathers in the valve covers with tubes connected to a remote can I used the frame as part of the system. No oil on the track. .
St. Jude Donor '09
I made up a stainless hardline from the base of the rear carb to the PCV valve in the rear of driver side rocker cover and ran a 5/8" hose to a puke tank with a breather on the pass side cover.....
WHY DO YOU HAVE A PUCK TANK?iS IT TO COLLECT THE OIL THAT MIGHT GET SUCKED UP THE TUBE.WHAT I WAS GOING TO DO WAS THE GET A PVC BREATHER AND GUT IT OUT AND RUN A HOSE FROM IT TO THE BACK OF THE CARB.
