What was you "AH HA!" mod?
That one mod that, had you known what what s difference it would make you would have done it first. For me it was the control arm bushings. What was yours?
Mine was converting from an auto to manual transmission, but I can't say I regret going BB or doing any suspension mods.
I am really happy with my 5 speed. It really makes driving the car much more enjoyable.
Putting the OD trans, better match for the 3.55 gear I put in 8 years earlier. Better low end gears, improved gas mileage when on long trips, and less motor noise when cruising at 70, (more then 1000rpm's less then before).
Recurved the distributer. Litteraly, I did the true duals and full length headers, and got less results that a 4 dollar recurve kit from auto zone. Ran so much better, too.
Since i'ts spread out over time hard to say...but here goes....
Wheels/tires 50 series/17" is easy number ONE....
then it's
rack steering, HB brakes, plastic rear spring, Bilstein shocks, that's all in the chassis dept....
DPFI for the engine, and O/drive 200 4r tranny....
the rest is bells and whistles the above is gut level performance....
then it's
AH HA (defined as unexpected results!)
i changed the jets to 55 from 60, and mpg doesn't go up(no ah ha even if it worked, as good results are expected),
then AH HA, i change the base gasket and it gos up 60% AH HA!
Location: San Diego - Deep Within The State of CONFUSION!
Finding the 4-bolt main block and building the 383.
Next I'd say it would be the dual spal fans. I tried lots of things to keep the stroker cool when using the A/C and none worked well enough for me. I even tried a single 16" electric fan and built a custom shroud for it. It ran warmer than with the OEM fan/shroud combo.
Now it runs right at what the thermostat is set to: 180*F or, with the A/C on it runs at 195* and I can definitely live with that!
I replaced the TH350C in my 81 with a 200 4R because the original transmission was shot and I figured the extra gear was worth the extra cost. Turns out that everything about the OD transmission works better.
An enormous improvement in the feel, acceleration and drivability of the car.
Hey everyone
700R4 and 2200 converter! It's a completely different car - absolutely the single best thing I did, and I did a LOTTA stuff to this car. I even helped build it (well, I disassembled the donor cores and cleaned parts and handed tools around, but I learned a lot about it - it helps to have a friend who owns a transmission shop LOL). Gas mileage is in the low 20's, first gear will spin the rubber off the tires, it will pull almost a whole car length shifting from 1st to 2nd, and overdrive and lockup lets me cruise in the left lane on the way to work, just like a regular ol' stiff
I rebuilt my car from a bunch of boxes and parts, including all the body and paint work - if I knew back then what a difference this would make I would have swapped it out waaayyy long ago.
Next on my list is the hydraulic brake setup from Durangoboy, but that's on the winter project list lol....
Cruising
4 hole carb gasket. who wouldn't want 18 mpg at cruise instead of 11? http://community.webtv.net/MATTGRU/carb
hi matt
do you have any pic's of the way you did the spacer/gasket
thanks m8
