Window crank removal
Old Jun 25, 2008 | 05:39 PM
Dantana's Avatar
Dantana
Default Window crank removal
Anyone give me a tip to remove my window crank so I can get the door panel off? I looked in my AIM and was expecting to see some type of clip and use my removal tool but there doesn't appear to be a clip.
Old Jun 25, 2008 | 05:46 PM
...Roger...'s Avatar
...Roger...
Should be the old standard clip.I use a small dental hook instead of the removal tool.Hopefully someone didnt get pzzd off and epoxied the thing.
Old Jun 25, 2008 | 08:18 PM
luerja's Avatar
luerja
the clip that holds it on looks like this
they make a tool to remove it but a small screw driver will work too to unhook it.
or a dental tool or anything with a sturdy hook
Old Jun 25, 2008 | 10:37 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Default window crank clips ?
Many moons ago when I was just learning about cars, from an older wiser car guy, I asked what these clips are called ?
he told me they are called Jesus clips !
I questioned why ? .... he demonstrated, by dislodging the clip,
and yelled out, as the clip went flying off ,
Jesus where did that thing go !!!
69VETT
Old Jun 26, 2008 | 12:37 AM
chvet73's Avatar
chvet73
I found that while trying to reach those things, it helps to push the door panel in around the handle. It will move a small amount and give you a better chance at grabbing the clip. The hook works the best.
To Window crank removal
