Transmission Fluid Running Hot ...
I have a '71 Coupe and have installed a Bowtie Overdrives 200-4R automatice transmission. Part of the package is a trans fluid temp guage and they recommend the temp should run at 150 or below. During the install I also added a B&M Super Cooler transmission fluid cooler. The install instruction for the cooler say to run fluid from transmission to radiator to new cooler and back to transmission.
Well everything worked fine until the clutch on my fan went bad. I ordered a new fan clutch and the holes didn't match. I figured they sent the wrong one and reordered. The holes didn't match again. Guess that means I don't really have a 71 fan. At this time I decided to switch to a chrome flex fan. Now all is good with engine temp but the transmission fluid temp is running at 180.
After reading a previous post I change routing of trans fluid from transmission to new cooler, to radiatior and back to transmission. No change.
So I think my problem is not enough air from fan or not enough flow through tran fulid lines in radiator. Can I run trans fluid through new cooler only?
Any thoughts.
Any thoughts.
Hi,
I've got the same set up from bto as well and fitted the middle of the three coolers they recomended ans have had no probs with temps no higher than 160c with a 2400 stall t/c installed.
What's your stall speed and size of cooler?
Peter
P.s. did you check you had a good flow through your old trans cooler on the rad?
Peter
Hi,
Peter
Peter
I am not a big fan of running the tranny cooler thru the radiator at all. I would just run from the tranny to the cooler and gack. Also those flex fans suck, they don't move enough air and they have a nasty habit of sending an errant fan blade thru some nearby fiberglass.
Your heta problem may also be because the TCC is not locking up and slipping all the time thus generating more heat. Check out the lockup issue first, then rerout the cooling lines and get a better fan setup in there.
I am a big fan of electrics, didn't used to trust them but the technology has come a LONG way in the last 20 yrs.
For my 2004R BTO I'm running from the trans to the rad and then thru the aux cooler on my 79. Normal op temps during the summer with A/C is 140*-150*. I'm with Six Shooter in that the TCC is not locking up. What I did on mine was to install a small LED on the console such that it lights up if 12v is running from the tranny relay to the TCC wiring. That way I know that I've got juice to the trans.
If the lockup isn't working on a converter designed with one the temps will skyrocket. Sometimes it can be hard to tell for sure. You could disconnect the wire for it and see if the cruising RPMs change any.
I tend to agree with above, in that it IS Florida and summertime, but with the obvious cautions in other posts....lockup and good fans, etc....180 is a problem for a 700/4l60e in that they have a 3/4 clutch heat/oiling problem....but I never heard the 200 has that issue anywhere....
