Too much cam?
Old Aug 19, 2008 | 11:26 PM
chevr0letman's Avatar
chevr0letman
Default Too much cam?
I've been hearin this for a while now:
"With stock pistons, crank, rods and such, you can't go over a 268 duration cam without deeming your engine with a short lifespan."
What's the deal???
Old Aug 20, 2008 | 12:01 AM
DRIVESHAFT's Avatar
DRIVESHAFT
What's the deal???
It has nothing to do with life span.
Performance may suck with a big cam, but it wont make your engine die.
Old Aug 20, 2008 | 01:49 AM
Little Mouse's Avatar
Little Mouse
Cast iron crank/cast pistons of an L/48 will handle RPM limited hydraulic cams. Forged crank/forged pistons L/82 will handle way more rpm then any hydraulic cam will allow or any cam considered streetable. 268 duration would be about the limit for a stock converter a good limit for the amount of low compression L/48, L/82 has to work with.
Old Aug 24, 2008 | 12:39 AM
chevr0letman
Well I'm getting new brodix heads, 700r4 high stall converter, and long-tube headers... so can i run a 272 duration cam?
Old Aug 24, 2008 | 12:57 AM
Scott Marzahl's Avatar
Scott Marzahl
Are you getting IK180s with a 64cc size? If so, using a GM .028" head gasket, that only puts you about 9.25:1, I'd say stick with the 262 or 268. IMHO, I'd use an Engle 1018H.
Old Aug 24, 2008 | 01:02 AM
Little Mouse
64cc Brodix heads will bring your comp. up enough to run that cam.
With the gearing of 700R4 mild converter go for it if thats the cam you want, 700R4 has a good size overdrive do you have 3.08/3.36 gearing in the back that much overdrive with this gearing would be hard to pull
on thg high way for a 350.
Old Aug 24, 2008 | 01:06 AM
TACatfish#64's Avatar
TACatfish#64
Default First off so you are comparing apples to apples
you should compare cams at .050 duration figures and not the advertised duration. The static compression with the heads you are buying will be a big determining factor on the cam you run if you don't have enough compression too large a cam will be something you really regret. Your motor should be looked at as a package and the sum of the parts is more important than any one piece. A looser converter will definaltely help things but what final gear are you running? IF you have 3.08s out back a gear change should be on the list judging from your choice of heads and the performance converter.
Old Aug 24, 2008 | 09:43 AM
SteveG75's Avatar
SteveG75
The problem is that bigger cam needs more RPM to make power.
Here is the issue. An L-48 bottom end is living on borrowed time above 5500 rpm. If you have a cam that makes power at 6500 rpm and you like to use it, you will be breaking parts.
Also, bigger cams like more compression. With a stock L-48 and a big cam, expect worse performance below 3500 rpm than stock.
To Too much cam?
