Pulley problems with new engine?
Old Aug 21, 2008 | 03:54 PM
corvettedave383's Avatar
corvettedave383
Default Pulley problems with new engine?
got a few problems with my new engine and old 78 vette pulleys
some pics to explain
http://s206.photobucket.com/albums/b...t=DSC00641.jpg
the two pelleys seem to be touching, too big??
http://s206.photobucket.com/albums/b...t=DSC00640.jpg
not on same bit?, need shims or ?
http://s206.photobucket.com/albums/b...t=DSC00639.jpg
http://s206.photobucket.com/albums/b...t=DSC00638.jpg
its scraping againest water pump?, shims?
http://s206.photobucket.com/albums/b...t=DSC00636.jpg
pic of water pump length
http://s206.photobucket.com/albums/b...t=DSC00635.jpg
pic of front end
http://s206.photobucket.com/albums/b...t=DSC00632.jpg
pic of balancer, its a pro sport
can anyone help me?
would I be better buying a nice march pulley kit, are they are simple bolt on kit??
thanks
dave
Old Aug 21, 2008 | 03:58 PM
Vette79C3's Avatar
Vette79C3
I can tell you from personal experience that you will probably have to use a grinder on the water pump to provide some clearance for the pulley's. I just went through this a few months ago. It's a Stewart Water Pump, right?
Old Aug 21, 2008 | 04:09 PM
V77Vette's Avatar
V77Vette
Old Aug 21, 2008 | 05:22 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
You have the opposite problem as this poster:
http://forums.corvetteforum.com/show....php?t=2111148
It is important to know that the SHORT SBC water pump comes in TWO different lengths - the one with a 5/8 inch pilot diameter is ~3/16 shorter than the later one with a 3/4 inch pilot, which is used on SBC Corvettes '71 and later. It appears that you have a the shorter of the two on your motor.
To fix, you can replace the water pump to one specific for your model year, or add some shims between the water pump pulley flange and the pulley.
If you find that the pulleys are rubbing, use a smaller diameter crankshaft pulley such as that used for the L82 instead of the L48.
Old Aug 21, 2008 | 06:08 PM
corvettedave383
not sure which water pump it is?, but it wont help it line up with crank shaft pulley, grinding the top bit of the water pump?
dave
Old Aug 21, 2008 | 06:18 PM
corvettedave383
is it ok to have a small gap between the balancer and crank shaft pulley, or is it ment to be flush, hard up againest it??
dave
Old Aug 21, 2008 | 06:20 PM
pws69's Avatar
pws69
You have a W/P pulley with a 3/4 hole on a W/P with a 5/8 shaft - that's simply wrong and should not be done (the shaft is what centers the pulley, not the bolts) - for a 78, you should be using a W/P with a 3/4 shaft, however, if the pulleys are touching, it's possible that that both W/P and pulley are wrong. Also, if those pulley grooves are aligned now, then it is also possible the crank pulley is incorrect!
Old Aug 21, 2008 | 06:31 PM
corvettedave383
thats fair enough, can you recomend the exact water pump to use(needs have good high flow rate, the engine goung to produce alot power in the near future, my present water pump has shims imbetween pump and block??
and you can recomend I nice set of pulleys for the vette, I only have alt, steering pump, no a/c.
can there be any issues with the timing chain cover and water pump?
cheers
dave
Old Aug 21, 2008 | 07:28 PM
pws69's Avatar
pws69
I have not used them, but from people I know have, the Edelbrock 8812 is a highly recommended pump for your application. Summit has them as part # EDL8812 - I will buy the 8810 for my 69 when the time comes.
I suppose it depends on what you want to spend. Always a favorite are March pulleys if the price doesn't bother you.
With the correct pump and pulleys, there should not be.
cheers
dave
And the same back at ya!
Old Aug 21, 2008 | 07:51 PM
corvettedave383
one other question, you can see that the crank shaft pulley hole is bigger than the pilot bit on the balancer, is that a problem??
cheers
dave
Old Aug 21, 2008 | 08:10 PM
pws69's Avatar
pws69
cheers
dave
Yep! There should be a large, 1/4" thick washer on the damper bolt. Summit http://store.summitracing.com/partde...1&autoview=sku
Old Aug 22, 2008 | 12:25 AM
Artsvette73's Avatar
Artsvette73
dave
The crank pulley should be flush to the damper
Old Aug 22, 2008 | 01:32 AM
larrywalk's Avatar
larrywalk
cheers
dave
The crank pulleys have a rolled edge which fits tightly inside the large center hole of the balancer. The 3 3/8 diameter short bolts hold the crank pulley to the balancer; the large 7/16 diameter center bolt with very thick washer holds the balancer/pulley combination in place on the crankshaft.
Old Aug 22, 2008 | 03:28 AM
corvettedave383
if we look at last photo, there seems to be a washer type thing on balancer, does that have to be removed then??, is ok to remove that, or will I upset balancer postion/timing etc?
dave
Old Aug 22, 2008 | 01:02 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you can remove the center bolt. the balancer is pressed on, and keyed to the crank.
just make sure you reinstall the bolt and torque it down .
69VETT
Old Aug 22, 2008 | 02:16 PM
corvettedave383
69VETT
thanks for that info, what torque level for bolt?
dave
Old Aug 22, 2008 | 03:10 PM
corvettedave383
ive tried undoing the balancer bolt, but it seems very tight, I just end up turnung engine over, what can I do to stop engine tuning over, all spark plugs are in?
which way for undoing, anti clockwise?
cheers
dave
Old Aug 22, 2008 | 04:01 PM
69Vett's Avatar
69Vett
counter-clock wise to remove the bolt.
you have to find a way to prohibt the motor from turning while breaking the bolt loose.
you can use another socket rachet on the other 3 bolts to lock it place, or just put the car in gear if 4 speed. I don't have the torque spec handy.
Bubba torque spec, torque it back almost as hard, as you use to break it loose.
Old Aug 22, 2008 | 04:44 PM
corvettedave383
ok cheers, give that a go
dave
To Pulley problems with new engine?
