one side has "rivets"(?) and the other doesn't. Is this because one side has been drilled out? I ain't drilling without knowing, never done this car before...............
Yes. You must remove the rivets if you plan on replacing rotors. You will hear different reasons for the reason why the rivets were used when the car was built. Some say it is because they were used to hold the rotors in place during the assembly of the car, some say to help keep the rotor "true" to the spindle, etc. They are not necessary to replace if you drill them out to reinstall the rotors. When you replace, be sure to check for runout or you will keep getting air in your calipers resulting in a soft pedal. Btw, the brake system is the same for the whole C3 generation with the exception when the general put stainless steel sleeves in the caliper bores during the 1979 model year.
Can you post a picture of where these are suposed to be I just replaced my rotors and didn't notice rivets anywere ?
They were in the 5 holes in between the wheels studs.
Okay I know what you R talking about the rotor I took off looked like a universal rim does with 10 lug hole but only 5 were use. The new rotors didn't have those just the 5 lug holes. You said
what do you mean check for runout? Cause I have a soft pedal bleed out all the air and my brake light keeps coming on when I press on the brake to hard. I was about to get the rear cali's rebuilt thinking there was a problem.
No C3 Corvette came from the factory with SS sleeves in the calipers. Aftermarket only.
The SS sleeves have no connection with eliminating the runout/air sucking problem.
Runout can be caused by warped rotors or a hub that doesn't run "true". It can be corrected by shimming between the rotor and hub. Like mentioned above, it can cause the caliper pistons to constantly move in and out, causing air bubbles to be generated at the seal area, resulting in a soft pedal. It can also cause squeaking brakes at low speeds that quiet down when the brakes are lightly applied.
Wow I have replaced dozens of rotors on my cars, trucks and bikes over the years and never checked for this once I guess I just got lucky. Is there a special shim kit for this ?
This issue is unique to 65-82 Corvettes, no other vehicles.
I picked up some shim stock from the local parts store and cut out some washers with siccors. .005" and .002" thickness will probably do it. A .005" shim between the rotor and hub on 1 stud will change the runout by around .010"
Okay the runout pretains to front & Rear correct cause my prob is coming from the rear. But if I pump the pedal it gets hard again
You presently have air in your brake system and need to bleed it out till the pedal gets firm the first time down. The runout problem "may" cause air to get into the system again, but only after being driven.
If anyone cares, I'm done and had to order new hardware kit for the parking brake. Thanks for the help. I knew that they had to be drilled out, just wanted to hear from someone else! Thanks C3 T/P
I bleed the brakes out they worked fine for a day pedal hard as a rock .The second day we took the car out I noticed some sweaking at slow roll then started noticed the pedal getting soft when I hit but when pumped it got hard .I thought the caliper was bad untill I read this post.
This is good news thank you for starting this post. It helped meto learn something new.
