78' brakes
Old Oct 8, 2008 | 02:49 PM
k78's Avatar
k78
1st Gear
Default 78' brakes
During the time of a few weeks my brake pedal went away. I bled my brakes,and still the pedal goes all the way to the floor. Now only the left front locks up; and if I hit the brakes very hard the car jumps left. The master cylinder always had plent of fluid.The brake pads are fine and I havn't seen any signs of leakage. Any help would be greatly apreciated.
Old Oct 8, 2008 | 04:08 PM
avner's Avatar
avner
On the rear wheel caliper you have two plugs to bleed in each caliper.
Did you bleed both of them in each side? You need to take the wheel off.
Avner
Old Oct 8, 2008 | 04:20 PM
Roughrider's Avatar
Roughrider
You may have a bad brake hose. They can collapse internally even if they look good on th outside.
Also, you might have a bad caliper seal. Normally that will cause a leak...sometimes they will suck in air and no amount of bleeding will cure it.
To 78' brakes
