TH350/TH400 Transmission Swap Questions
Senior Member
Received 2,031 Likes
St. Jude Donor '10
I have a local gentleman selling a TH400 automatic transmission he had rebuilt then removed from his GTO. I have a TH350 in my 77 Corvette now. I am replacing the engine with the GM Crate 350/290. Three questions:
1) Would it be a good idea to buy and install the TH400 to replace the TH350?
2) How hard a swap might this be when the time comes to do it?
3) Anything I need to watch out for?
Thanks in advance.
David
Thanks in advance.
David
The 350 is more than capable of handling the motor you have listed. The 400 is a HP robber. It is a great trans and can handle a lot of HP but it also takes a lot of HP to drie. I would stick with the 350 you have if it is in good shape.
Senior Member
St. Jude Donor '10
Excellent, thank you. I think I need to pull the TH350 and have it gone over as the car has 85K on it and to my knowledge has never had this serviced. Would the same be true if I used the GM 350HO with 330HP?
Thanks a bunch for your help.
David
David
Senior Member
St. Jude Donor '10
Thank you.
A GTO (Buick-Olds-Pontiac) TH400 has a different bolt pattern than a Chevy engine. You would also have to have a Corvette-specific yoke and change the driveshaft.
Senior Member
St. Jude Donor '10
David
