How fast will a C3 go?
Old Feb 15, 2009 | 08:51 AM
  #201
roscobbc's Avatar
roscobbc
Originally Posted by 3JsVette
Well lets see with almost 40% more cubic inches, somewhere near 550 horsepower, and a final drive gear below 3.00 do I really want you road testing my car? Are you crazy?
You better be carefull! Or you know what could happen............
Hmmmm......... I'm running genuine 528 hp with a 3.08 & 4 speed and its a ***** cat to drive (still not too happy about going into upper three figures though)
Old Feb 15, 2009 | 12:35 PM
  #202
angelthrust's Avatar
angelthrust
Originally Posted by Gordonm
Cmon guys. A C3 running 200 mph. You are going to need a good amount of HP and good aero. The C3 is not very sleek, as much as we think it is. The difference between running 140-150 and 200 is huge. You think the Nascar guys are spending millions to get that extra few mph and you are going to take a stock bodied C3 with some extra HP and run 200. I would love to see this done but it is going to take some heavy mods to do it.
Yea I have had mine at 140 with what seems like a lot left but to get another 50or so mph out of it, I seriously doubt it. I don't know how "built up" your 427 is but you have better be packing some serious HP to get to 200. Lokk at all the Bonneville racers and see what it takes to go 200.
seriously... remember what it took to get the sledgehammer to 200?
Old Feb 15, 2009 | 01:49 PM
  #203
KevinK's Avatar
KevinK
Originally Posted by vettesbydesign
Not so much.It IS sorted under power,and hard acceleration,but running,or rather trying to run at a constant speed on the highway....I have to keep feathering the pedal to keep it at speed.If I am running around 78mph,or more,then she is fine,but below that....
It took me about 200 stops in parking lots w/small screw driver,and allen wrench to get the car sorted out before where it was streetable,then I went,and changed the engine up,and I'm not pulling alot of vacuum at idle,and tuning is a B@%ch!!!!!But...I am persistant,and coming off that exit ramp onto the interstate,and climbing up....pretty fun,and pulls great.
I have that same problem, in a STOCK (mostly) 76.
I just chalked it up to the differences between FI and Carbed.
Old Feb 15, 2009 | 03:30 PM
  #204
Taijutsu's Avatar
Taijutsu
Default Pratical Application?
My 74 has 3:55 rears and 325 rwtq @4100 rpm.
Lets assume that I have taken off the side mirrors, lowered front 2.0" and have the PC aero kit.
If the car is turning 3,000 @ 70 mph, and an .70-.68 overdrive would reduce rpms to about 2,000 rpm, that should = 140 mph @4,000 rpm.
Q: Will 325 rwtq make 140 mph?
I don't want to run much faster than that and I do not want to rev any higher. I'm thinking about the Silver State. Where am I wrong? TIA
Ricisan
Old Feb 15, 2009 | 05:59 PM
  #205
Billysvette's Avatar
Billysvette
I tell you guys it isnt the hp that gets you its the body and air deflection.I had plenty of hp 500+,i could have gone faster easier,but at 150 this body style will not let you go faster.It wants to lift you off the ground,im telling you ,my hood lifted up about 2 inches from the air pressure underneath the car,maybe its my cars body style being a 69 ,maybe the newer c3s are a little better. I think you should be happy at 140 mph
Besides you can only beat a newer vette in a quarter mile,or short run,thats what i shoot for.
Old Feb 15, 2009 | 07:08 PM
  #206
vettesbydesign's Avatar
vettesbydesign
my motion scoop bulged up on the blast,and alittle over 130 my headlights came up,and open on their own.
it's all in fun,until I loose my liscense.
Old Feb 15, 2009 | 09:21 PM
  #207
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Ricisan
Probably, but I might suggest (not knowing your torque curve) gearing to reach 140 at an rpm a bit nearer your redline would make it an easier target.
My view of the Silver State is that it's nothing to take lightly. Even tho my shark is fairly well prepared I wouldn't think of running it without a considerable amount of further development, especially in the area of safety equipment, despite (or perhaps due to) my RR experience. Of course, nothing says you have to actually compete with the likes of Big Red to take part, but that's a difficult concept to grasp for some of us. As many others have already pointed out, you'd best pay a lot of attention to aero issues (a little rake ain't enough) if you plan on going truly fast.
Old Feb 16, 2009 | 12:43 AM
  #208
Taijutsu's Avatar
Taijutsu
Default Aero's First!
SW: For an event like the SS, I would extend the stock air dam a few inches. What else can I do?
My engine is all forged internals and HR cam w/RRs. I am confident that it will hold together at 4,000, anything higher for an extended period scares me.
The fastest Touring Car class is 125 mph. After that I would need extra safety equip. I plan on 4 pt bar w/harness and Recaros eventually.
Ricisan
Old Feb 16, 2009 | 02:12 PM
  #209
TheSkunkWorks
Ricisan
Myself, if I didn't feel pretty comfortable with running beyond 4000 rpm for 90 miles I'd be having second thoughts about doing the SS, as I believe the engine should be the least of your concerns; but that's a call I can't make for anyone else. That said...
Other than meeting event requirements, whatever else you might do in preparation one thing you need IMO is a radiator/cooling system with a capacity at least equal to, if not greater than, your max HP output. It's possible to get away with less rad at the strip or for the occasional short bursts of speed on your favorite stretch of road, but not over an extended period. And, don't overlook the balance of any and all other plumbing, as it only takes one tiny leak to put you off in a big way. (Hwy 318 doesn't exactly have FIA certified run-offs.)
Another thing, just how well sorted is your suspension? Whether you intend on pressing limits in the curves or not, the better handling is your car the more margin you'll have when (not if) something unplanned happens. Next, since after the green waves isn't the time to discover such issues, how do you plan on verifying aero balance and that lift has been adequately countered?
Bottom line: my philosophy is that one ought to KNOW if and how their machine is going to perform before heading out to any "speed event". FWIW, I consider it a healthy sign if all of this makes you at least a little nervous; brave not being the word coming to mind in describing anyone who wouldn't be. If you go for it, here's wishing all the best.
Old Feb 16, 2009 | 06:22 PM
  #210
Taijutsu's Avatar
Taijutsu
Default Thanks for the Advice.
SW: My 74 isn't close to being ready for the SS. I have upgraded some systems to whats needed "11" dual Spals and 140 amp alt", engine needs headers and ex. My suspension and brakes are not even close, wheels and tires are down the road.
I have finally gotten things to run w/o drama. Like many project cars it has taken more time/money than expected. I have lurked the threads of you fast guys for a long time. Since I don't drive it much, I would feel real bad blowing the engine before I really got to enjoy it.
I wouldn't dream of doing anything real fast w/o pro inspection.
I just want to drive fast w/o going to jail.
Ricisan
Old Feb 16, 2009 | 08:14 PM
  #211
vettesbydesign
Ricisan
Amen to that!!!!!
Old Feb 16, 2009 | 08:52 PM
  #212
Bigblok's Avatar
Bigblok
Default Buy a C2 and go 240 !
Old Feb 16, 2009 | 08:57 PM
  #213
mrvette's Avatar
mrvette
Amen to that!!!!!
OR having a tire blow, and getting painfully DEAD over it...
at that point, screw the damn tickets......
Old Feb 16, 2009 | 09:29 PM
  #214
68 NJConv 454's Avatar
68 NJConv 454
I agree with SkunkWorks. I overbuild everything to give me the margin of safety of "what if's". And patience is the difference b/w a safe run and regret. Don't put your car or you life on the line unless you are 110% certain both are ready for the task. Safety first! then its all fun. Good luck
Old Feb 16, 2009 | 09:43 PM
  #215
63mako's Avatar
63mako
St. Jude Donor '08-'09
Well my stock 72 was floaty @ 120 MPH. My 63 is rock solid @ 146 MPH. That was all it had. Maybe the body kit side vents and chin spoiler help with high speed stability.
Old Sep 2, 2009 | 01:28 PM
  #216
Vicar's Avatar
Vicar
Cruising
HOLY CRAP ! That '63 of yours might well be the most beautiful car I've ever seen. And apparently it handles way better than the C3 as well. Alas it is a bit more expensive then my '77
Anyway, getting back to the original question: how fast will a C3 go? : my personal experience says it will do 120 mph at least. But at that speed my car already becomes very 'light' and you get scared ****less when you think about what will happen if a bump in the road would occur...
So I never got it up over that. My car has a '74 , 454 ci BB with .06 overbore, edelbrock performer carb, hooker headers and some more. 700r4 tranny, stock ratio diff. 275r15 rear, 235r15 front.
I seriously doubt I could reach the top speed of this car and live to tell about it.
My dad in my car
Old Sep 2, 2009 | 02:34 PM
  #217
gkull's Avatar
gkull
Originally Posted by gowhitten
I am trying to figure out how fast my old C3 might go. I have a '75 C3 with a built up 427 ci engine, Holley double-pumper, 3.08 posi rear-end and 700r4 tranny built to Bowtie Overdrive stage 3 specs. My brother is thinking about taking a couple cars next year to the Texas Mile and I wonder, with a little work and a roll cage, whether or not it is worth throwing the car on the transporter.
For those of you that don't understand ONE MILE Drag racing. It is a MPH event not a number of seconds. With one of my 383 ci motors i was able to attain nearly 165 mph in the standing start one mile. For comparison at the same event mildy modded C-5 Z-06's (chip, cold air, exhaust) were generally in the low to mid 150's.
The 700-800 hp cars with power adders (supercharger or N2O) were 175-190 mph 1000 hp and turbo bikes were over 200MPH
I at the time had a 4.11 rear and 700R4 that had the ability to run wide open throttle in 4th gear OD. Your 3.08 rear is going to suck.
I also went out and practiced a bunch of times on my local roads. most freeways have mile marker posts. I would just come to a stop on the freeway at a mile marker post bring up the rpm against the brake, let off the brake and floor it just like for a 1/4 mile drag race
Go out there at your home and see what you can do. If your car feels unstable over 150 mph, just add stiffer springs/body rake/aerodynamic mods.
5 speed manual OD's with a 4.11 like mine work much better than automatic cars.
You can look up at the one mile sites online and they post what mph what cars are getting.
To How fast will a C3 go?
Old Sep 2, 2009 | 04:06 PM
  #218
hugie82's Avatar
hugie82
My 82 w/2:78 rear and .78 OD cruises 80mph at 2000rpm. With good low end grunt I can get it to 3800 -4000rpm. Than just like you said it doesn't have the power to push it through the air but I'll bet I'm doing a good 140+ with 200hp and 285tq at 2800rpm
Old Sep 2, 2009 | 04:59 PM
  #219
larryg3's Avatar
larryg3
Originally Posted by Ron R
It comes in handy when you get pulled over. "Do you know how fast you were going?" "Yes sir, 85 Mph."
Old Sep 2, 2009 | 05:14 PM
  #220
SEVNT6's Avatar
SEVNT6
How fast? All I'm going to add to this thread is how my steering felt..
Very light & uncomfortable..........
