Carb linkage question
I am using the Holley Street Avenger carb, with the factory linkage. I have the bracket already attached, but I want to make sure that both cables are located correctly.
I am pretty sure that the lower stud is for the throttle cable, although the stud is too wide, and the plastic sleeve doesn't let the throttle open all the way. I think I have to order a narrower stud and cut off the plastic sleeve.
However, I am not exactly sure where the kickdown cable goes. Does it go on the second stud that I have circled? Also, does the cable mount somewhere to keep it from moving all over?
Thanks,
Doug
If the throttle stud is on the upper one, I am not sure how to mount the cable because the upper stud is closer to the carb itself. The adapter bracket lines it up right with the lower one.
