New Engine Build 383 Help
Old Feb 15, 2009 | 02:31 PM
  #41
ShakeyrayStingray's Avatar
ShakeyrayStingray
Good Points Mouse! So, I have been enlightened even more, if you modify the new rpm intake it can be used with the ik200's. I guess the main descrepancy now roller versus solid.
Old Feb 15, 2009 | 02:37 PM
  #42
Scott Marzahl's Avatar
Scott Marzahl
As I stated earlier, you can match port the intake manifold to the 1206 Fel Pro part number intake gasket that the IK200s require.
Old Feb 15, 2009 | 02:49 PM
  #43
ShakeyrayStingray
Got it Scott,
Old Feb 15, 2009 | 03:31 PM
  #44
Little Mouse's Avatar
Little Mouse
I would like to suggest you don't use a high volume pump, high volume pumps are ment for engines with increased bearing clearances you will have no need for one.
If your fathers block is a 90 it will use a one piece seal crank it will require at least another flywheel not sure about the balancer. you can use an adapter use the older two piece seal crank.
Solid cam/lifters will be around $190.00 better then a hydrauilic flat tappit, hydraulic roller would be better when things are kept at lower street rpms. you will have to make up your mind if the extra cost is worth it to you.
Keep in mind with a 3.75 stroke you will most likely need a small base circle cam factory roller cam engines never had this long of stroke, may not be ground on a small base circle.
Old Feb 16, 2009 | 10:45 AM
  #45
ShakeyrayStingray
Well thanks everyone! I will probably decide the camshaft a little later. I am still a little undecided but have enough information to make an educated decision (instead of guessing, lol). I am going to my dad's to find a block soon, hopefully. The forged assembly will be on the way. I will be posting back when I get the block all ready and start the bottom end,
