vibration at highway speeds also... still
Old 03-02-2009, 10:33 PM
pauldana
Support Corvetteforum!
pauldana's Avatar
Default vibration at highway speeds also... still
I have read threads for hours and still have no solution. I have done everything that everyone has suggested... I have a 79 l82 4 speed, and everything has been changed, ether because I blew it up or chasing this darn vibration. It is the same as the person that had a similar post.
History, have had the car since about 1981, I was 21. When I got it it ran as smooth as silk, at 100+ it just squatted down and hugged the road, it was wonderful, that was then this is now...
somewhere along the line, and I don't know exactly where it went south, started handling like a boat on the water and vibration started coming through the shifter, and steering wheel, around 70 mph, Seems to be worse under load, ether acceleration or deceleration, but smoothes out somewhere in the middle..When I was young I was not so rich and only made repairs when needed and when I had to. so recently I went to work on my Baby
The following have less than 2,00 miles on it: 383 stroker balanced, Richmond super T-10, Richmond rear-end, balanced half shafts and drive shaft new ujounts, rotes, calipers, front springs-550, trw rear, Bilsten sports, All new interior, Shifter linkage, tires & balanced 3 times on different machines, Centerforce clutch, duel exhaust, borla mufflers. Trailing arms were replaced 30K miles ago, front A-arm bushings 10K with poly. I have got almost $20K in this car in the last 7 months in just mods and repairs. And the vibration continues.... Faster than hell, but feels like a 70 dodge truck on a bad road at around 70. Rev engine, no vib, coast at 70, 80, 90... no vib, BUT drive at 70 and the tank returns. AAAAAAHHHHH!!!!!!!!! The only thing I can think of that is left is this drive train alignment... which nobody in town seems to understand. I do most all the work myself because I like to and have been working on cars all my life out of the love for them, also it seems that no matter what I pay they do it half ***... help.... please???
Old 03-02-2009, 10:42 PM
wombvette
wombvette's Avatar
Look at the rear axle shafts. Is the rear low, is the camber to much negative, are the axles at the very least straight out. They should be slightly higher at the rear end. Misalignment here will cause vibration when the engine is pulling. Also check for half shaft yoke wear. It is very common on this particular model.
Old 03-02-2009, 11:01 PM
pauldana
pauldana's Avatar
New rear end all (less than 2K like everything else))... Eaton carrier, Richmond R&P.... O and the 3rd one:-)... I have a tendency to be brutal to them... all have done the same as I remember, I rebuilt the first 2, this on was built by a guy back east, Had it checked by th local rear end guy also while he was balancing all the shafts and he said it was a great job... just right,,, tight, but not to tight...
Old 03-02-2009, 11:12 PM
pauldana
pauldana's Avatar
Rear is to high if anything...and the rear has new yokes, but i would be willing to check them again... how would you check them other than feel for looseness?...
Old 03-03-2009, 12:27 AM
wombvette
wombvette's Avatar
A high rear and a lot of negative camber can bind the u-joints. It will cause buzzing vibrations.
Old 03-03-2009, 07:22 AM
pauldana
pauldana's Avatar
well... that is what i have, a buzzing vibration, and it is as irritating as heck. so you are stating to just have the rear aligned? and you think it will go away?.... that would be the cheapest fix so far... im in DC right now, but when I get home this weekend I will have the rear alignment done... anything you believe I should look out for? thx...
Old 03-03-2009, 09:14 AM
rj8806
rj8806's Avatar
...... The only thing I can think of that is left is this drive train alignment... which nobody in town seems to understand. ....:
If you want to check the drivetrain aligment, I will try an outline the way I do it here in house.....
With the car sitting at ride height, get a reading from the bottom of the tail housing near the end of the case itself (call this reading " A "). Next, get a reading from the middle of the driveshaft tube ( call this " B " ) and finally, with the pinion yoke turned vertically and the c-clip removed, place a socket that has the same diameter or slightly smaller, than the u-joint cup, on the cup and get a reading from the pinion yoke (call this " C ").
Now, take A - B = front working u-joint angle. Next, take C - B = rear working anlge. It is these 2 working angles we are concerned about. They should be equal but opposite (i.e. +2* -2* or +3* and -3* etc...) they cannot vary by more than 1/2* and none of the readings can exceed 5*.
Ideallly we shoot for readings in the +2*, -2* or +3*, -3* range when we set them up here and we have never had any vibration issues when we followed these steps.
I am not saying this is what's wrong with your car, only responding to your statement in your 1st post. Good luck and if I can be if any help, please don't hesitate to contact me. I will help you out as much as I can.
Richard
Tech Support
interpon (04-19-2022)
Old 03-03-2009, 02:17 PM
Thmprr
Thmprr's Avatar
You said it had a 383 stroker balanced. How? Internally or externally, I have seen this many times where the owner has had an externally balanced engine and had it rebuilt or purchased a crate engine, then refitted the external balanced flywheel and balancer. Shake City!
I have also seen the reverse of this as well, and particularly the one pc seal cranks need a specially balanced flywheel to be in balance.
One way to eliminate the drive train, is to get the car to the speed where it's vibrating and slip it into neutral. If the shaking instantly changes, its related to the engine. This will not eliminate the driveshaft, however.
Old 03-03-2009, 03:01 PM
rj8806
rj8806's Avatar
He said he can rev the motor and it is smooth but has it when he is driving and on the gas. If it were an unbalanced rotating assembly(such as you describe) then it would vibrate when the car is not moving(sitting still),and revving the motor(bringing up the rpm's).?
Richard
Tech Support
Old 03-03-2009, 04:06 PM
pauldana
pauldana's Avatar
ok... let me redefine, this vibration is only at speed, say 60, 70, 80 mph, it is a buzzing vibration, and it is present on load only, ie acceleration or de-acceleration, if you look for that sweet spot in the middle with the transmission still engaged (T-10) buzz or vibration goes away... this is why i believe it to be a alignment problem. if the rear/ transmission was out of up or down alignment it would only buzz in either acceleration or de-acceleration one or the other, but if alignment was out left right, ie pinion facing front passenger and transmission yoke facing rear passenger it would make sense to me to be doing this. Has anyone else had this problem? I do believe I have read this in other post and there was an alignment check and someway to realign it... how?
Old 03-03-2009, 04:07 PM
pauldana
pauldana's Avatar
o... internally balanced, new pioneer harmonic balancer
Old 03-03-2009, 06:14 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
I didn't see anything about the age or condition of your tires. Even if they are new, a bad belt in one can give you similar problems. If tires are not the problem, I'd suggest that the flywheel got mis-indexed somewhere along the line...
Old 03-03-2009, 06:44 PM
1hotrod
1hotrod's Avatar
Maybe a bad motor mount?
I just changed mine out, and it was smooth running before to 100, but lately at 80 my rear view mirror was vibrating to a point where I could not see anything out of it.
Old 03-05-2009, 02:00 PM
pauldana
pauldana's Avatar
I'm going to bring it by the alignment place in 2 weeks and get a 4 wheel alignment and have them check everything they can and maybe I'll find something there. The tires are new but as with most 15" rim tires they are junk... no more HR, ZR or?? for us... I will be going to a 17" in about 3 months..,We replaced the motor mounts with the new 383 2K miles ago... Rubber ones,... So I would think they would still be good... p:-)
Old 03-05-2009, 02:07 PM
pauldana
pauldana's Avatar
Fly wheel myth/topic?? Went to the machine shop that did the motor work and ask them about all that I have red about out of balance flywheels, here is what they said: A fly wheel that is out of balance was most likely turned on a brake rotor machine, and a lot of people do that, since it does not bolt up correctly this is what causes it. They turn there flywheels on a machine made for that purpose only, so there is little to none, and more likely none that a flywheel turned this way would be out of balance. This was Adams metelizing and they have been in business doing this for over 50 years. So I am going for that my flywheel is ok. p:-)
Old 03-05-2009, 03:01 PM
70BBvert
70BBvert's Avatar
Flywheels should be blanchard ground, not turned on a lathe. It's more precise and leases a distinct overlapping pattern on the face.
Also check all the bolts on the bell housing & transmission to make sure they're tight. I remember someone here found some loose bolts solving a difficult to diagnose vibration
Jim
Old 05-01-2009, 12:29 PM
pauldana
pauldana's Avatar
Well... this is an old problem, but here is what I have done since the last post. Replaced all pulleys with March aluminum, redone the complete front end with all new polly, 4 wheel alignment,,,, still got VVVVVIIBBBBB... AAAAHH!!!
So, I am still on the thought of a misalignment between the engine/transmission and the rear-end.
I took a laser level and set it up to align with the transmission/engine and the laser ends up pointing the the right rear. Then I took the laser and set it up on the rear-end and it pointed to the right front... so instead of a Z alignment or a straight alignment I have a U.... Which I believe would give the vibration under load ether gas on or gas off.... but no vibration in the sweet spot in the middle..
here are some pics of the laser alignment.
To vibration at highway speeds also... still
Old 05-01-2009, 12:32 PM
pauldana
pauldana's Avatar
more pics
Old 05-01-2009, 12:52 PM
midyearvette
midyearvette's Avatar
more pics
you could be the victim of a bad diaphram in the clutch, could be cracked and hard to see.....also a mis aligned hub or bent clutch disc at the input shaft......good luck......
Old 05-01-2009, 01:55 PM
pauldana
pauldana's Avatar
This vibration was present BEFORE the new clutch, and new engine, and transmission and drive line and rearend and...........
Quick Reply: vibration at highway speeds also... still
