Snowman's C3 Project Car
#41
1 Post
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
I'm away from the house til later in the week. Will show pics of front and back of the dash. Also will show pics of the Hot Rod Air unit under dash and front of the firewall.
Doug
Doug
#42
I wanted to make sure that the fuel pump would always have a supply. 2 AN-8's cleared the rear frame with less grinding than an AN-10 bung and connector would have. They come together in a Y fitting, then through a 100 micron filter with shutoff valve, through the pump and then through a 40 micron filter and up to the fuel regulator in the front of the car.
No the AN-8 doesn't have baffle or anything on the inside of the tank on the return.
Doug
I really like the rear end pic of your 65 roadster. Tried to find other pics. Do you have a site with more pics you could refer me to?
Doug
Doug
Doug
Hey Doug the My corvette link on avatar should have worked? No big try this: http://forums.corvetteforum.com/phot...?ppuser=224339
#43
1 Post
#44
EDIT: brain fart just looked at your first post- Jim Moore he helped me tons as well great guy. He was just telling me in a email about your deal. How funny I just put two and two together- I so smart..... Man he gets around, where does he find the time???
#45
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Yep that's me!
Sorry I haven't called you back yet! I stored the number....just haven't stopped long enough to be sociable!
I'm in Columbus Indiana this week at meetings with Cummins engine Co.
Work keeps cutting into my play time!!
But hey Doug....I did get a couple of confirmations on our latest work being done today! More to come!
You guys are going to like this buildup....Doug is just showing you the tip of the iceberg!
JIM
JIM
#46
Yep that's me!
JIM
JIM
It's all good Jim, I figured as much. I love my Cummins say hi to the guys at the factory. leavin today to stretch the big six's legs on a road trip. TTYL
Denis
(Blue cars rule)
#47
That will be a screamer!!
However, what's the deal with the mechanical fuel pump?? Shouldn't you be using a electrical pump with that kind of power?
#48
I am sure Doug or Jim will chime in but the mech pumps will support a huge amount of HP today and are way more dependabale and cost less. I know guys in drag boats running 800hp with Clay Smith mech pumps. In previous pics Doug does show an elec. pump so not sure what they have up their sleeve.....
#49
CI 7-8 Veteran
That's just setup for the engine break-in. A lot of those parts you see in the picture won't make it into the final engine configuration into "Bruiser". Jim used a break-in stand that I used from one of our buddies in our club:
#51
Yep.....mechanical pump is for test stand. If you read above you'll see Doug has a full Aeromotive fuel system on the car
The Demon carb was used to fire it since I didn't have enough fittings to hook the Holley to the mechanical pumps lines and the Demon has the weird fittings. But it was great for test firing. The valve covers in the picture rubbed on the shaft rockers slightly, so I pulled covers off my car to run on it while breaking in cam. The electric water pump drive was the one I use on mine at the track.
That intake is getting some special surgery right now.
As I said...you guys are going to like all the info that comes out of this build!
If I don't get this thing on the dyno soon...there won't be enough parts to keep my car running!!
More to come.......
JIM
More to come.......
JIM
#52
1 Post
If we don't get it on a dyno soon, I will have to use a sawzall and some rattle cans of paint to get the car ready for BG.
Yes have Aeromotive 1000 fuel pump and matching regulator. Plenty of fuel and fuel pressure when the time comes!
Denis, you should probably be told that in the last two days we have been talking about putting a Cummins diesel in Jim's 66...we like the videos from the tractor pulls and thought they show promise!
Pictures of progress tomorrow everyone. Sorry for the delays.
Doug
Doug
#55
1 Post
Yep. I am going to paint calipers tomorrow. Will also call you about fuel line fittings to reorder what I lost. Let me know when you can come in. Tue works for me.
Doug
Doug
#57
Doug
Doug
Denis
#59
1 Post
As promised, pics of the rear.
Son of Tranzilla Tranny in a box waiting
Car's a little light in it's shoes at the moment...no motor, no interior, no gas but you can see we will need some flare work.
