Stock air cleaner or aftermarket
Hello,
I have an 81 with an aftermarket air cleaner. Everything else is stock including the carb, which will probobly be replaced soon. I have read where the stock air cleaner on these cars works better than the aftermarket ones do. I have most of the old stuff, it just needs to be cleaned and painted. Is it worth it to put the old stuff back on?
Thanks!
Todd
Thanks!
Todd
I'm going to be reusing my stock air cleaner on my '77 when I redo my engine compartment next month. All the aftermarket ones suck in hot air from the engine bay,while the factory ones suck in relatively cool air from ahead of the rad.......cooler = better in my book
I reused my air cleaner- but painted it hi temp silver and clear coat, with a K&N inside, and a chrome/ K&N lid. I removed the dual snorkels since they surprisingly don't fit with the L88 hood- but the engine compartment looks cleaner without them anyway, and I don't notice any change in performance of the rebuilt 355.
Also, the stock air cleaner was chrome and powder coat black. It should just clean up and not need paint.
God bless, Sensei
I will probably replace the carb with the same thing or have mine rebuilt. The last time I had it in the shop I was told that he could not get it to "open up" all the way and that I would need to get another one sometime in the near future. The computer is still in the car and I don't want to mess with that if I don't have to. Thanks for the responses!
Todd
Todd
God bless, Sensei
I believe that the '81 carb was a one-year only design which had some electronic gizmo in it which helped the control system set correct fuel density (or something of that nature). It is difficult to find anyone with the knowledge to rebuild it correctly. But, if you want to keep it stock [and I would, if I were you], keep that carb...the engine won't run as well with a 'basic' Q-jet carb. You may want to search for info on that specifc carb and how to check it out. I believe that the Chevrolet Chassis Service Manual for '81 has detail on how to check it out and how to adjust it; it does not have info on rebuilding it. [Just trying to make you aware of some things to consider.]
I would prefer to keep everything stock with maybe a few minor modifications. The car seems to run fine to me. I would like to get a little better mileage if possible. I currently get about 15 MPG now and that maybe all I can get out of it considering that the sticker says 15 MPG.
God bless, Sensei
If your going to rebuild your Qjet, you may want to send it to Cliff at Cliffs hiperformance. He's been dealing with Qjets for many years and just might be the man to redo yours. I have purchased parts from him in the past and his products are top notch. Heres a link to his website, and also check out the forum...lots of good info there
http://cliffshighperformance.com/
It has headers and true dual exhaust, so I have that covered but they did not have a bung put in for the O2 sensor, so mine is missing. Would that have an effect on mileage?
God bless, Sensei
When I was behind the guages I noticed that the check engine light was removed. I was shocked because NOBODY removes that light, right? Anyway, I've been wanting to get that back in and maybe get some performance back. I think Bubba may have worked on this car before.
