'68 fuel overflow tube?
Any chance this is an overflow tube? It fell off the car when I was removing the spare tire carrier.
The tank is new, and there is no rubber boot around the filler neck. Is this where the tube connects, and if so, can the boot be installed without dropping the tank?
Thanks. '68 SB
Thanks. '68 SB
Thanks. '68 SB
Thanks. '68 SB
Pretty easy to install the rubber boot around the neck from the top. That was one of the earlier things I did when I got my 68. The rubber is pretty soft and bendable and you just stuff it in.
Most often it is a no drain tube. If stopped up, and it usually is, water will enter the gas tank and cause a bunch of grief. So it is better to leave it off and save your gas tank.
