An aquaintance has a 74...and the lock has jamed in the locked position with the door closed... any ideas how to get the door open? Thanks in advance. Muddy
Hi muddy......it happened to me too. on my 81. tripple a time. they can get it open, but tell them in advance so they send out the right gang member. on another note........were in merced ca. you guys ever go to cherries jublie thing in monterey? pretty cool for the price. and gets us out of the valley heat for the weekend. I think we will take the vette this time. good luck with the door.......bryan.
bryan: Hello...so your saying, call AAA or a locksmith? Cherries? Heck ya....every year, lol. There is usually a couple of my buddies (with C-3's) that park together. Laguna Seca, Canery Row and the Warf. This year there will be 4 of us maybe 5 actaully. If you come....there could be six Yea bring the Vette.
Remove the door panel on the OPPOSITE side of the car. You can then see what door lock levers to "jimmy".
With the window DOWN on the offending side, you will have enough room to get a tool (coat hanger) down into the door lock mechanism.
The problem may be a worn door handle mechanism or a gunky lock.
Scroll down to DB's thread and he has an excellent picture of the door lock mechanism with the "key" lever you must push to release the door latch. Once you find the lever, you can reach down from the window opening with a long screwdriver and place the blade on the lever. Give the screwdriver handle a sharp blow and the latch will release. You can do this with nothing more than having the window down all the way.
Here's the picture... copy it to your files or print it out... if you own these cars long enough, you're gonna need it...
First thing to check is make sure the outside door handle is all the way up. If its sagging, the lock mechanism won't unlock, or if the linkage to the outside door handle is out of adjustment, same issue.
Good luck... GUSTO
Thanks Gusto I'll pass this on... Two issue though, the linky does not work, and the other issue is, (well for me anyway) is, that my 72 has a plastic guard over the mechanism Muddy
Aktbird: Thanks, I'll also pass this info on Muddy
Muddy,
Yes there is a plastic cover that sits on top of the lock mechanism. It is a very lightweight plastic cover that keeps water from running directly over the lock that finds it's way inside the door. You should be able to move it aside without damaging it and get to the lever on the lock that needs to be depressed.
Funny the link and picture worked last night when I posted it. I do have the picture on my hard drive at home and can email it to you if you'd like. Just send me an email address if you want it and I'll shoot it off to you.
It's one of those tasks that if you've done it a few times, you have no trouble locating the lever and opening the door. It has been a lifesaver for more than a few friends over the years.
I had this happen with my 69 years ago before I removed the levers and latch assembly to clean and adjust.
I was able to work the lock **** and inside handle until it released. Try to unlock the **** while ratching the inside lever. If this work pop the panel and look closer. I had the 90* rod ends bent on one and the latch gummed up. Remove the latch, clean with brake cleaner and dry lube it. Then setup and adjust the rods.
About as much fun as grouting Mexican tile.
I noticed that the picture is once again linked above. If you place the tip of a long handled screwdriver on the lever (arrow is pointing to) it will release the latch.
I agree with what others have said, if you remove the latch mechanism and clean it good with a strong solvent it should remove all of the old grease. Once you get it thoroughly clean re-lubricate it with lubriplate (some call it white grease) it should be good for another 10-20 years.
It's been my experience that these things tend to get gummed up from old grease well before the fail from wear.
Hey there Gary...must report, the box is still humming sweet!!! And yea, I can relate, nothing worse than wide Mexican joints!! Thanks for the tip! Btw TG, I pullled mine out...and completely cleaned and lubed...still working sweet
Good luck... GUSTO
Thanks Gusto...that's exactly what I did to..when i had my doors off, and all apart (white grease) btw: I had my mechanisms sitting in parts cleaner for a couple of months, before I got to them Muddy
