Transmission fluid
Old May 18, 2009 | 11:02 PM
raulotero91's Avatar
raulotero91
Default Transmission fluid
Hey guys, i seem to be having an acceleration problem. I have a 79 small block. The car is not accelerating as it used to. It is hesitating as i press down on the gas. I have to stomp on the gas in order to start accelerating. the only thing i have recently done is replace the water pump, and the radiator hoses. is this problem related in any way to the cooling system? Should i replace the transmission fluid? any help would be appreciated
Old May 18, 2009 | 11:36 PM
7T1vette's Avatar
7T1vette
It could be a number of things. Is this something that made an abrupt change? (yesterday it worked fine...today it doesn't) Or was it gradual? Bad fuel batch; ignition system problem; accelerator pump on the carb is wearing out; distributor advance (mechaical part) is malfunctioning; clogged fuel filter; pinched fuel line; failing fuel pump; etc, etc. The most likely is a worn accelerator pump seal, closely followed by ignition/dist. problem [IMO].
Old May 18, 2009 | 11:58 PM
Ward72's Avatar
Ward72
My luck is always that I knocked something loose. I would look around to see if you did.... my guess is maybe a vacuum hose. Good Luck!
To Transmission fluid
