Fast Idle After driving
Old May 20, 2009 | 10:44 PM
kwikcc's Avatar
kwikcc
Default Fast Idle After driving
73 vette 350 automatic rochester carb. At start up the car idles nicely and runs great. After driving the car for a while the engines idles fast about 1000-1200 rpm when shifted into park or neutral which causes a rough shift back into drive or reverse, anyone have any suggestions where I should begin to look.
As usual thanks for all your responces.
Old May 20, 2009 | 11:52 PM
noonie's Avatar
noonie
Easy checks first.
Your choke is completely released.
Your butterflies are closing completely to the stop screw.
Your advance weights move smoothly and are returning to no advance position.
Old May 21, 2009 | 08:11 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old May 21, 2009 | 08:26 AM
Attfay Elleybay's Avatar
Attfay Elleybay
about a month ago mine was sticking. A shot of WD40 on the throttle cable and it's fine now.
Old May 21, 2009 | 12:54 PM
Vegas69's Avatar
Vegas69
I had the same issue. My throttle return spring was weak. I replaced it with a little heaver spring, go to go now.
Old May 21, 2009 | 04:07 PM
smon's Avatar
smon
Is your choke working when you start the car...
Maybe your idle screw is too far in and it is high enough to let it idle cold and when the car warms up it is too high. I was having a problem similiar to this, but I knew my choke wasnt hooked up and needed the high idle.
If you let the car warm up in the driveway does it settle down?
Sean
Old May 21, 2009 | 08:49 PM
kwikcc's Avatar
kwikcc
yes the car idles slightly fast at start up then down after warm up. The only time it seems to idles fast is after driving it for a while and shifting into neutral or park the idle speed stays fast and you can't tap it down.
thanks for the help it is greatly appreciated
To Fast Idle After driving
