Starter or safety neutral switch???
Old May 21, 2009 | 01:24 AM
78vette78's Avatar
78vette78
Default Starter or safety neutral switch???
i need more opinion before i change my starter. How will i now if my safety neutral switch needs to be replaced.
my car always starts first in the morning. it only wont start again after i drive the car.
i just want to make sure its not the safety neutral switch. Do u guys know how will i find out if my safety neutral switch is bad???????
thanks in advance.....
Old May 21, 2009 | 01:56 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Sounds like the problem the previous owner had with my white79.
I had the problem driving it home the 1000 miles after purchase. Couldn't even jump it. Hour later it started right up.
I simply disconnected the battery cables, made sure things were clean, and reconnected them. No problems in 5 years since.
Make sure your ground cable connection right below the battery box is clean and tight.
Replacing the starter may fix things simply because you're disconnecting and reconnecting the cables, not because you have a new starter.
Old May 21, 2009 | 02:30 AM
Peterbuilt's Avatar
Peterbuilt
Try all of the above and if your Vette still will not start when hot confirm that you have 12 volts at the "S" terminal at the starter ( the purple wire closest to the block ) if you have 12 volts there, with the key on start, than you need a new solenoid. PG.
Old May 21, 2009 | 09:34 AM
7T1vette's Avatar
7T1vette
The only way to know for sure that the neutral start switch is operating correctly is to 'dig' down to it and check for continuity when moving the shifter through the ranges (engine OFF). If working properly, it should make connection anywhere in the neutral range and in Park...but should not show continuity in any other range. The NSS and the starter solenoid are your most likely 'culprits'...but a bad wiring connection or a starter with worn-out brushes could also be the problem.
Old May 21, 2009 | 09:42 AM
08vycpe's Avatar
08vycpe
I had a '69 El Dorado that did the same thing. Turns out the carb was bad causing raw gas to enter the cylinders and hydrolock when hot and couldn't turn over. When the engine cooled down and the gas evaporated the car would start right up.
Do all the others have suggested and take the starter down to Autozone and have them check it out for you.
Old May 21, 2009 | 02:16 PM
C3Rocket's Avatar
C3Rocket
Cruising
I have had this problem, too. From what I have been told, it is a common problem...it is the starter getting over-heated next to the exhaust manifold (or header). You have to wait until it cools enough before it will start again. Solution...from what I am told, a new starter will help if you are still running an older or original starter...and/or installing a thermal cover around the starter to protect it from the heat. I, myself, plan on doing both...getting a new starter and then wrapping it in the thermal cover.
hope this helps...
Old May 21, 2009 | 02:30 PM
...Roger...'s Avatar
...Roger...
Run a temporary setup like this drawing and the next time the car wont start watch the light-if it lights then like Pete says replace the solenoid-if the light doesnt light then you can look at the neutral safety switch,and other PURPLE wire connections.
Old May 21, 2009 | 03:45 PM
7T1vette's Avatar
7T1vette
Excellent idea! If the bulb lights, you know that the solenoid is getting the 12vdc signal to it. If the starter doesn't turn over, it would have to be the starter solenoid (or, less likely, the starter and/or cables).
Old May 21, 2009 | 07:00 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
a sheild is better than a wrap,
the sheild allows airflow, the wrap also holds the heat in a starter.
You never wrap an electric motor/starter.
To Starter or safety neutral switch???
