Richmond Super Street 5-speed w/OD!!!
This is for the Richmond Super Street 5-speed w/OD.The trans is rated at 600 lbs./ft. of torques,and comes w/Long shifter.26 spline input,and Turbo 400/Super T-10 tail yoke.
1st:3.33,2nd:1.85,3rd:1.31,4th:1.00,5th: .77
This is for the trans w/shifter,and my modified trans mount shipped to your door in the lower US 48.
I sell Tremecs,and ARE a great product,so nonthing bad to say,but Richmonds are smaller,so no tunnel interference,no shortened driveshaft,or special yoke,bolts to all early GM design bells,or aftermarkets.
$3425.00 to your door.
Do you have access to the version with a 2.89 1st gear. I intend to use a 3.73 diff and a 3.33 1st would be to much.
With the Richmond will I be able to use the original drive shaft from my 77 th350?
