BB. oil -intake issue?
I removed the intake to fix an oil leak at the back and oil fouling the fifth cylinder spark plug.
attention : new GMPP cylinder heads and just 200-300 miles after new heads...
I have found all the intake valves with a good deposit of oil on them. less one . the fifth cyl intake valve is clean like new with fluid oil ( but lot of oil goes into that cyl and fouls my plug quickly)
by a visual check of the intake gaskets removed, I don't see great issues. I'm going to make a dry fit of the intake later today to see if it matches correctly or not
more: the fifth cylinder bore is the only of 8 to have a "ridge" at top. suspecting an oil leak there I have used in the last 300 miles 20W50 oil , but no difference in respect to a lighter oil.
today I have made a pressure test with compressed air applied through spark plug and cyl 5 behaved like cyl 3 ( that has no oil leak)
any idea?
I forgot.
I don't see unusual crankcase pressure. no oil in the top of intake and in its runners. so I don't think it's oil getting into , through the PCV circuit.my valve covers have oil shields too.
the plug was oil fouled at cyl 5 also before heads replacement. on old iron heads I found a worn valve guide and I judged the problem was that. but still oil now...
why all these problems at the same cylinder while all the other not?
Doug
-the intake is the Alu L72 type. I see no damage or crack. I have done a test right now making a test fit with some grease applied . the match between intake and heads is OK. but the problem could be the use of the rubber-cork front and back selas. they rise the intake a bit. I will use RTV only this time
-I have already used the sealant on intake bolts
what else?
I'm going to fit again the intake tomorrow using a better FelPro performance , blue , instead of a cheaper Fel pro type used before. the one I'm going to use is all rubber, the other was metal inside-rubber outside
