15x8 Cragars to 16x8 Rallies
Will I have any issues if I go from my current 15x8 Cragar S/S wheels with 4.25" of backspacing and 1/2" spacers to a 16x8 Rally with 4.5" of backspacing if I want them to sit in the same position as the Cragars? I would assume I would need 3/4" spacers for the difference in Backspacing + spacer currently being used but by doing so will I run into problems with the acorn style lugs and my studs not being long enough then? I just want the 16x8's to sit in the same position as the current 15x8's and need to know what I'm getting into before I take the plunge? My plans are to use the 16x8 Rallies and mount some 295/60-16's for the rear, which are slightly taller than the 295/50-15's but the same width.
I just got the 295/50-16 tires and just need to find some wheels and there arent a ton of choices so I was thinking the Rallies would look nice but I'm open to any suggestions.
Thanks for any help
Thanks for any help
Yes but I dont know when that will be yet.... The set-up I have now is 15x8 Cragars with 4.25" of BS on all 4 corners with 275/60-15's in the rear and 255/60-15's in the front.
The sooner I find wheels that I can get to work with the new tires, the sooner I will have my current set-up for sale
Tires and wheels just arrived, just need to have them mounted now to see how they fit.. Tires are 28x12-16.. Wheels are 16x8 "chrome" Rallies.. I was thinking of going with chrome baby moons for the center caps.
Received 3,043 Likes
St. Jude Donor '05
What are they, look bigger than a 295/50
Fronts are 275/40x17 and rear is 285/40x17. Still too small for the rear, but the widest tire I could properly get on a 9" wide wheel. Goodyear Eagle F1-GS/D3's
They are 295/50-16"
The 295/50-15, which most use are 26.7" tall and the 295/50-16 is 28" tall but they are both the same width.. I thought is was kinda strange that just the wheel size made such a difference in over-all tire height. I personally like the 28" tall tires because it fills the wheel well better.
St. Jude Donor '05
nice...thought the 295s were 10 in wide for some reason, guess they are 12. Looks good.
There, now it doesnt look so naked in the back
Just need to get the matching fronts and the baby moon lug covers so I can take a picture from the side too.
To give you an idea of the size of these rear tires, the fronts are 255/60-15
6th Gear
Wheel Size and modifications
I have a C3 1979 Corvette. I want to replace the stock wheels which measures 15" x 8" with a back step 4" which is currently installed on the car. I would like to go to 16" x 8" by 4.25" back step. Notice you used tire size 295/50-16 tires B.F.Goodrich are they the same size tire and wheels front and rear? If so what modifications did you have to do on the rear trailing arms for the parking cables mounts? and does the tire stick out of the wheel well at all? Wheels that are going to be ordered are American Racing Custom Torq II vintage style. Please respond by email to stealth799@gmail.com my tech wants to know the info as well.
George
George
George
George
The front tires in the above pictures are still the Cragars with 4.25" of BS and 1/2" spacers and 255/60-15 BFG tires.. My new front skinnies should be here next week and I'll post a picture after they are installed.
I dont think it would be worth it unless you picked them up and I live in Northern Michigan, in the middle of know where
I just dont want to go through the trouble of shipping them and I'm sure it would cost a fortune anyways.
$600 if anyone wants my Cragars and BFG's and that includes the lugs.. Tires and wheels are all like new..
