turn signal fuse blown need help
71 vette LT1 all park lights work just no turn signals replaced flasher and 20 amp fuse and it blew again. I am leaving for Bowling Green next wenesday be nice to have turn signals any information would be helpful thanks.
If you have had the dash piece under the column off lately make sure you didnt put a long screw in the center screw hole. It sometimes goes into the front signal wires and shorts them out.
The "flasher" in the fuse block is NOT for the turn signals....it's for the emergency flasher. The turn signal flasher is located behind and toward the bottom edge of the right side dash panel. There is a clip on the backside of the panel where that flasher unit is placed. Replace that flasher with the one you removed from the fuse panel...it's probably still good.
answer to your other question the dash pad has not been out of the car in over a year and everything wes working fine until the fuse blew.
Try leaving the flasher out and then replace the fuse and see if the fuse blows when you turn the key on. That will help us. If it blows with the turn flasher out you have to unplug the neutral safety switch next.( a shorted through flasher should only leave the lights on with no flashing)
It could be a failure of the turn signal switch itself. There are metal springs/parts which could cause such a short if they are broken and/or got loose into the electrical contacts.
Thanks for the help car is going to a repair shop tomorow may see you in BGif you are going staying at micro tel exit 22 off 65 my car is a steel cities gray LT1 conv.
We disconnected the new turnsignal wire and plugged the old one in and it worked fine.
When we took the steering wheel of we saw where the screw touched the wires.
All we had to do was to tape the wires and put it back and everything started to work allright
what ever ya do, don't trust those GM wiring diagrams
the 71 was even writtin about here on the forum
really sad stuff
http://oosoez.com/curr-evnt/currentevents-101.html
really sad stuff
Any ideas why it won't blink correctly? Did my turn flasher decide to go? All other lights work as they should, brake, reverse, headlamps.
