I was wondering if there was anyone here that has put a frame and suspension from a c4 under their c3. Mostly I was curious about how much work was required to switch it over.
You can buy a SRIII frame for $5-6,000.00 that uses C4 chassis components but you can't put a stock C4 chassis under a C3. I probably shouldn't say can't because there is no doubt someone who has tried it but in almost 10 years on the forum I have never seen anyone post any information on such a swap.
My buddy has a friend who put a C-4 chassis under a 1973 corvette. I have not seen the car, but it can be done. I will check on it for you a reply back.
google "street shop" and click on the 1st link that comes up and you can answer your question. There is also someone on another Corvette forum with a blue '69 Corvette that built a C4 suspension and while he did a great job it appears to be a lot of work.
Hi S75,
I looked at the Street Shop chassis at their booth at Carlisle today.
It looks pretty terrific, but takes some serious $$$ to do well.
Regards,
Alan
Hi S75,
Regards,
Alan
Did he have a '78 Pace Car in there on one of his chassis? He does nice work.
I will be very interested to see how he did that considering the C4 was a unibody design. A quote from HowStuffWorks:
The old perimeter-type ladder frame was replaced by a steel backbone design not unlike that pioneered by England's Lotus. In the Corvette, the "spine" took the form of a C-section beam rigidly connected to the differential and carrying the driveshaft. This arrangement reduced weight and opened up more cockpit room by eliminating the transmission and differential crossmembers, and by permitting the exhaust system to be run beneath the driveshaft instead of alongside it.
Welded to the backbone was what Chevy called an "integral perimeter-birdcage unitized structure" or "uniframe," making the new model the first Corvette to employ modern unit construction instead of the old body-on-frame configuration.
I verified with my friend, and it was done on a 1971, not a 73. I don't have the details. I don't know what parts he used. Next time I see him I will ask.
I put the front end out of an 88 in my 75. Its not completely done yet but getting close. It was a lot of work. since I havent drove it yet I can't say if its worth it but I would think you could get more bang for your buck (in hind sight). there are a few people with C4 rears in their cars. i looked into doing it but decided it was too much work/money at one time.
As we have seen from other posts it is possible to install a C4 suspension on a C3 frame, especially if you use a custom frame. Until you can provide some pics of a C3 body installed on an entire C4 frame I'm going to have to call on being able to do an entire chassis swap as asked by the original poster. I'd love to be proven wrong but I think your friend's buddy may have been just dealing with the suspension not the entire chassis.
