Convert to Electric fan
Old 10-11-2009, 11:32 AM
carriljc
carriljc's Avatar
Default I used a Mark VIII fan and DC Control
Works like a dream. But I do like that Ford Focus dual fan arrangement that Sharkinthewoods has.
here's link with bunches of pictures
http://forums.corvetteforum.com/c3-t...t-you-got.html
Old 10-11-2009, 10:32 PM
cart3113
cart3113's Avatar
Thanks for all the replys and info.
Jim
Old 10-11-2009, 11:42 PM
Dantana
Dantana's Avatar
Tell you this, I bought the kit with the dual Spals from DeWitts and I've talked to Spal and DeWitts about why the only time they will come on is when I jump a wire from the end of the thermostatic switch to ground. The problem appears to be unsolvable, I even bought a new thermostatic switch, no help. At this point they either don't run at all or they run all the time. When they are on, the engine runs cool all right. Sure would be nice if they worked right. You can chronicle my efforts in my other post:
http://forums.corvetteforum.com/c3-t...-question.html
Mighty expensive upgrade to have everyone stumped on the reasons for malfunction. Answer probably hiding in plain sight, but no one can see it so far.
Old 10-12-2009, 12:32 AM
chvet73
chvet73's Avatar
I did the Focus fans too. Did not build a shroud. Just made mounts for it. Works great.
Old 10-12-2009, 07:22 AM
1982CorvetteDude
1982CorvetteDude's Avatar
Originally Posted by Gordonm
Dewitts dual Spal fan setup. Not cheap but pretty much bullit proof.
I agree with the bulllit-proof statement, but I save myself over $100 getting my dual spal fans on fleabay
Old 01-03-2010, 09:33 AM
NBC3
NBC3's Avatar
What year was the focus? Do you have pics of the install? I am interested too. What about wiring? Can you list what you had to source and how you wired it up? Do both fans run all the time? How is it set up?
Bill
Old 01-03-2010, 10:38 AM
L79racer
L79racer's Avatar
Go on ebay. There is a a couple of guys selling new 3.8 Taurus fans for $76 including the shipping. They fit and work great.
Old 01-03-2010, 02:22 PM
70 LS1
70 LS1's Avatar
I am using a dual fan setup from a 97 Camaro. Fit pretty well and was cheap. I am also using fuel injection, so the computer controlls the fans in two speeds.
Low temps or freeway speeds, fans off.
As it heats up, slow fans kick on.
Heats up more and fast fans kick on.
I picked up the fans for $100, relays for about $30. I already had the wire laying around and since it is controlled by the PCM, it just used the stock LS1 temp sender. You would need two temp sensors for the dual speed setup if you were doing it yourself.
I also have a manual override switch under the dash, so I can turn the fans on manually anytime I want.
Old 01-03-2010, 03:56 PM
mrvette
mrvette's Avatar
I have thought of a simple DTDT relay and maybe a SPDT relay hooked up to have one sensor turn on the fans running in series with each other, and if needed run in parallel then by pulling in the DPDT relay.... each fan would draw only 1/2 the voltage and make 1/4 the power/air volume movement, but still maybe enough, then switch to high for a/c or temps....
Old 01-03-2010, 04:25 PM
70 LS1
70 LS1's Avatar
Thats how my setup works. Slow is in series, fast is in parallel. Uses 3 relays.
Old 05-13-2011, 09:51 PM
Aruba1
Aruba1's Avatar
I found a set of dual spal setup for $130 on CL. Dual 11", shroud, both harness, both relays and the temp switch. All brandnew :-)
I am needing pics of duals on a stock 1968 radiator. Can anyone post pix of their setup?
Old 05-13-2011, 10:48 PM
phildawg19
phildawg19's Avatar
mine did the EXACT same thing. i just wired them to stay on all the time. with the heat down here though they would be on all the time anyway
Quick Reply: Convert to Electric fan
