Best Carb suggestions?
We just buy 1 gallon and ride up RT 1 until it runs out.
Thanks to everyone for their comments, even billa, it helps make this place interesting.
- 4165 is best.
- the 4165 can't be beat in terms of LOW COST, MPG, POWER and FUN to drive.
- I can compare it to converting to EFI, because YOUR GAS SAVINGS WILL NOT LIKELY PAY FOR THE EFI EVER, not if you don't lose HP (with a cheap old unit).
- That is my challenge to you . compare a 4165 to EFI
. It cruises along very efficiently on those puny primaries.I'll stay out of your ongoing wager
I agree with Billla that EFI is better than a carb, in just about all respects.
I agree with Matt that I would not swap a carb to EFI because of the expense. Billla's cost analysis is reasonable for a daily driver, but I rarely drive a collector car even 2000 miles/year. That would be a 16 year break-even. I have found maintenance on cars with injectors (my '85 Eldo has throttle body injectors) is worse than cars with carbs, if the car spends lots of time sitting. Could just be the Caddy, but those injectors get clogged up if I do not run the car every few months.
Though I am impressed with Matt's mpg, I really do not drive the cars enough to care about mileage. That is not true of my daily driver however.
Lastly, I did buy a 4165 to rebuild, just to see how it compares to my Qjet, and because I wanted to see how manual secondaries performed on my '74 454. For the $39 I paid for it (plus another $39 for a rebuild kit, which I think is a little expensive for a kit) the cost of running the test is relatively inexpensive, as Matt pointed out.
I may buy one just to see if it has healing powers, or if I rub it if a Genie will come out...
All this over one carb. A good one at that - but just a carb.
To all
I offer my opinions based on my experience. Guys often run off on a tangent without first ASKING if that is what i mean. Example, IMO everyone should have a good cheap DD "snow car" that has EFI and gets great mpg. This is IMO a better use of $2200 than converting a c3. Then, we will get some guy that misinterperts that; that claims i want us to sell our C3's!
so when u get confused, the proper thing is to ask for more details as as Golden did.U don't have to follow my advice, but, at least find out what todays advice really is.
And, for variety i try my best to offer DIFFERENT advice whenever possible. This is to keep from being bored saying the same thing over and over. This can rightly confuse people, and you really need to spell out your situation in detail.
And my statements are not fixed in stone. I've gone into the archives looking for some old data, and read my comments from years ago, i often wince and think, WOW my opinion has sure changed!
My best writing is on my web pages. This live forum is chat. Impulsive, in the moment stuff.
Anyone that made a copy of my web page say, 1 year ago, would find numerous changes, my goal there is to make it better and easier to understand.
It looks great though, cant wait to hear it run! Thanks for all the advice and information!
Everyone should do their own research on anything they read in a chat room! I bet if capevettes didn't chime in and confirm the 4165 as a great carb, 71coupe454 might not of bought it.
Billa is lazy and wants me to do his homework. Not going to happen.
I've done my homework; you should do yours. Lazy is never learning by working on other cars or other carbs, and just parrroting the same tired
take note at the minimum speed the qjet spins the tires. compare to the 4165
2nd test is to completley let up on the gas at say 4500, note how hard it slows in 1st or 2nd, and when it drops to 2500, nail it! Have plenty of room, as it may go sideways w/4165
Keep us posted! U have a $78 tiger there
Billa,
I'm Lazy. I admit it. I don't even have a pc. Too lazy to learn how to fix one. i use a $99 1998 webtv.
I cancelled my order for a new c6. Too lazy to make room in my garage. Too lazy to study the 3000 page service manual.
I don't have a shop, i was just jerking you around as u were acting like a jerk. I retired 7 years ago. I can do, or not do, whatever I please.
I'm not backing up my claims, because the essense of my point was confirmed by capevettes.
Removed the leaking QJet, the original leaking QJet was replaced when my 68 was under new car warranty. Best gas mileage of 18 mpg on interstate trip.
The Holley 6210 is a 650CFM and installs on the original intake with no adaptors, the choke works on mine hooked up to the original location of the Qjets heat spring operation mounted on the intake.
I also installed the same type Holley 6210 spreadbore double pumper on my 1970 350/300 Corvette on 1974. Would still be using it but I installed a ZZ crate engine in my 70 and the ZZ's engine came with a square bore intake. I experimented using a adapter/spacer to continue using my 6210 but not enough hood clearance when using the spacer.
Bought a Holley square bore type carb. Best gas mileage ever was a trip coming back from San Diego to Dallas, 22mpg computed on two fill ups during the trip.
Recommend not using the ported vacuum connection coming from the metering block for anything on your car. You can use a T plastic connector in the vacuum hose from the full time vacuum port at the base of the carb to supply the needed vacuum to operate the choke and vacuum advance.
68 is 4-speed M21 3:70 and 70 has turbo 400 3:08 Both have full time vacuum advance.
Thanks for chiming in!
I'd like to make a note of square bore carbs that get good mpg.
22 mpg wTH400/308 is excellent! What was the cruising speed? or RPM
Can u give the List # off the air horn so i could pass along this info?
No shop, huh? That explains why you declined my offer. Nope, you're not backing up your claims - because you can't.
Can you put me back on your ignore list, please? I liked it there
my, u have a vivid imagination
i said i'd charge u the standard $90/hr shop rate.
That is because i can sub-contract the work.
Never said i had the shop; but they are available.
I'll make u a deal, i'll ignore you, if you ignore me
Matt, I'd never make a deal with you because you simply wouldn't honor it. Wasn't I already on your ignore list? So just ignore me.
