List of Flat-Tappet Oils - Page 36 - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
Old 08-27-2017, 07:14 PM   #701
ykf7b0
CF Senior Member
Has anyone tried Lucas Break In Oil 10631? Their numbers for zinc and phosphorus are way above all others.
ykf7b0 is offline   Reply With Quote
Old 08-28-2017, 06:16 PM   #702
greggome
CF Senior Member
Any opinions on Rotella oil for flat tappet motors? Shell claims it still has 1200 ppm ZDDP in its T4 15w- 40 & 10w-30.
greggome is offline   Reply With Quote
Old 08-28-2017, 08:47 PM   #703
LenWoodruff
CF Senior Member
LenWoodruff's Avatar
Quote:
It was recommended by my engine builder and I have a friend with a 66 Vette with L79 327 that has been running it for 10 years.
I would like to know what the difference is in this oil VS regular oils other than the ZDDP
LenWoodruff is offline   Reply With Quote
Old 08-29-2017, 12:56 AM   #704
billla
CF Senior Member
Support Corvetteforum!
St. Jude Donor '14
Answered in the original post; the detergent package for diesels is *very* different than those for gasoline engines.
Why use a diesel oil when there are so many good choices specifically designed for our engines?
billla is offline   Reply With Quote
Old 08-29-2017, 09:23 PM   #705
greggome
CF Senior Member
Thanks. I have heard in the past that folks were using Rotella for the elevated ZDDP levels and since Rotella is half the price of most of the other oils with high ZDDP I was wondering if it was appropriate to use and save some $. These specialty, racing and synth olis have gotten so expensive lately. Of course if its not good to run in my car I will avoid it for sure and spend the extra . Also Mobil suggested their turbo diesel truck oil which has phos of 1100 and zinc 1300 but is not cheap as Rotella. Thanks for the opinion.
Old 09-03-2017, 07:13 PM   #706
NRAROX
CF Senior Member
NRAROX's Avatar
billa, I don't think this link to AMSOIL works any more. Am I wrong? I cannot find anywhere in any of their technical documents where they specifically state their ZDDP levels. It's always scary when numbers disappear.
AMSOIL says that "ZDDP levels in Z-ROD Synthetic Motor Oil exceed the limits of API SM and newer specifications.", but I cannot find where the API SM spec contained in the API standards indicates a ZDDP requirement.
(Synthetic) AMSOIL Z-ROD Synthetic Motor Oil
Links provided by Corvette Forum Vendor C66 RacingLLC (PM 'Subdriver')
Grades: 10w30(ZRT) , 20w50(ZRF)
Claim: "AMSOIL Z-ROD Synthetic Motor Oil is formulated with high levels of ZDDP to protect flat-tappet cams, lifters, rockers and other areas susceptible to wear. Its high-zinc, high-phosphorus formulation provides the extra wear protection these critical splash-lubricated components require."
Verification: ~ 1320 PPM: http://www.amsoil.com/techservicesbu...t%20Tappet.pdf
NRAROX is offline   Reply With Quote
Old 09-04-2017, 08:26 AM   #707
LenWoodruff
CF Senior Member
Can I ask where you got this info?
I couldn't find any 10W-30 T4 so I used the T5 Blended.
I would like to know the ZDDP content for the T5
Old 09-04-2017, 09:16 AM   #708
LenWoodruff
CF Senior Member
I did find these T5 10w-30 Rotella Test Results dated 2014. This is Cj4/SM rated which is what is on my oil bottle.
http://www.pqiamerica.com/June%20201...llatT51030.htm
Old 09-04-2017, 12:32 PM   #709
billla
CF Senior Member
St. Jude Donor '14
Thanks for letting me know - I'll follow-up with our on-forum distributor guy!
Old 09-04-2017, 07:40 PM   #710
greggome
CF Senior Member
The information came to me via email from Shell technical support it read as follows "The Shell Rotella T4 15w-40 and 10w-30 still have 1200ppm of ZDDP and are suitable for use in a gasoline engine.
Sincerely,
Don
Shell Technical Information
1-800-237-8645"
Hope that helps
Old 09-04-2017, 07:51 PM   #711
LenWoodruff
CF Senior Member
Sincerely,
Don
1-800-237-8645"
Hope that helps
Thanks for the info. I will give them a call tomorrow,
Old 09-05-2017, 01:46 PM   #712
LenWoodruff
CF Senior Member
Thanks Don for the contact info.
I called the Shell Tech line specifically about the Shell Rotella T5 10w-30 synthetic blend.
If the package says CJ4 then it has 1300 PPM of zinc and 1100 Phosphorus.
They are coming out with a new blend that is CK4 and it has 1200 PPM of zinc and still around 1100 ppm of Prosperous.
Old 09-06-2017, 05:52 PM   #713
Mark_Milner
CF Senior Member
One thing that would be helpful is since talk about flat tappet protection depends somewhat on spring pressures, maybe including some spring pressures and how much zinc would be a good idea.
Something like:
xxx lb - light pressure, aaaa ppm ZDDP needed
yyy lb - moderate pressure, bbbb ppm ZDDP needed
zzz lb - heavy pressure, cccc ppm ZDDP needed
Yes, ti says we need at least 1000 ppm, but then it is mentioned in several locations you can get away with less with light pressures and slow easy ramps, but need more with heavy pressures and aggressive ramps. But what are we really looking at on pressures ramps?
Mark_Milner is offline   Reply With Quote
Old 09-07-2017, 12:09 PM   #714
billla
CF Senior Member
St. Jude Donor '14
Amsoil links updated thanks to NRAROX for catching it, and C66 Racing for providing updated information.
Old 09-07-2017, 12:23 PM   #715
billla
CF Senior Member
St. Jude Donor '14
Quote:
I don't know that anyone has that verified information. We could say generally that for lift over .550 and/or turning over 6K RPM or so you should probably be using a racing-class oil with very high ZDDP...although if you're building at that lift level a roller cam is a far better choice.
The comment regarding mild cams was more to point out why some folks note to have used low-ZDDP oils with no issues. As an example, many Chevy lo po performance engines use the venerable GM "390" cam with .390 lift and a very mild ramp and extremely low spring pressure...especially for high mileage engines that rarely see more than 4,000 RPM.
Old 09-12-2017, 12:12 PM   #716
mullvamp
Junior Member
mullvamp's Avatar
I used synthetic oil in my 502 flat tapped cam gen 5 440 hp since ca.22 years (55.000 kilometers) without any problems. The engine was new.Pressure ok., consumption ok, no leaking.
The make is : Castrol Edge 10/60 full synth.
I am wondering why many do have problems with oils like this.
Regards from Germany, Kalle
mullvamp is offline   Reply With Quote
Old 09-15-2017, 11:23 AM   #717
68post
CF Senior Member
The oils produced to sell in your market are formulated with different chemistries ,(by law), than the ones sold here, so it very well may be an "apples to oranges" comparison within the same product.
I don't know that we even have an Edge 10w-60 here !
68post is offline   Reply With Quote
Old 09-15-2017, 12:34 PM   #718
billla
CF Senior Member
St. Jude Donor '14
It's covered in the first post, but the problem overall seems to be old, hard seals that are maybe getting a little sealing help from gunk and varnish. Synthetics are more solvent, and dissolve those deposits and expose bad seals - nearly always the front main seal.
Newer engines with modern seals have zero issues.
Old 10-23-2017, 10:48 PM   #719
63mako
CF Senior Member
St. Jude Donor '08-'09
63mako's Avatar
63mako is offline   Reply With Quote
Old 12-10-2017, 11:44 AM   #720
corvetero
CF Senior Member
corvetero's Avatar
That's the oil used by the BMW M3 E46, I'm pretty sure that can be found in USA
corvetero is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • List of Flat-Tappet Oils
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    AMSOIL Releases new high ZDDP Classic Car Synthetic Z-ROD Line C66 Racing Autocrossing & Roadracing 14 09-20-2017 09:55 AM
    Test Data on Amsoil Dominator Racing Oil 540 RAT C3 Tech/Performance 15 08-15-2017 10:18 PM
    Oil Reviews-let the discussion begin sycraft C7 Tech/Performance 14 04-29-2016 08:35 PM
    Quaker State’s New “Defy” Motor Oil – Lab Test and Wear Test Data 540 RAT C3 Tech/Performance 20 04-27-2016 07:57 AM
    Tags
    0w40, 1030, 5w40, acessesories, btwn, c3, corvette, legal, mobil1, not, oil, purple, racing, royal, shootout, specialty, street, truck, valvoline
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
