help with headlights
are the headlights supposed to go up and down when you push and pull on the headlight switch?
and are the outer lights the brights or the inner lights?
and can someone tell me where to get a good vaccuum and wiring diagram for the headlights?
i know the left side vaccuum acutuator is out,it wont raiase the headlight bucket with out me helping it.and i know the headlight switch on the dash has no vaccuum lines going to it.(i think it supposed to).anyway,they are not illuminating now.high beams either.i need a wiring diagram and/or vaccuum diagram.thanks
Leeroy
http://willcoxcorvette.com/repairand...1221d8fa61b645
http://willcoxcorvette.com/repairand...60ee78cd4b2508
The brights are on the inside and the regular driving lamps are on the outside.
You should have some vac lines running to the headlamp switch, If you search the forum you might be able to find a diagram. I do not have one handy now or I would e-mail it to you.
Chk your fuse box and make sure the mounting screws that hold it to the wiring harness are tight. Thats where my problem with the light not turning on was.
Hope this helps out and maybe someone else will chime in with more info. Tim
black:ground
brown:high beam
light green:low beam.
i can power up the low beam wire and the headlamps come on.
the headlight switch turns on everything else except the headleamps.they were working last week.is there a headlight electrical relay?
black:ground
brown:high beam
There is a dimmer switch in the steering column.The yellow from the switch feeds the dimmer. Both the green and brown run out of it.
Sounds like you are not getting power on the yellow to the dimmer. Check this.
The other things work because they run off different wires from the switch.
Jim
